1 - 20 of 24 Posts
Hey everyone,
Is there a walkthru on here that shows step by step how to do a brake job (pads, rotor, etc) for the rear wheel (drum) brakes? I cannot find anything...
I have a '92.
Thanks!
Thanks! I've never tackled a rear wheel drum brake setup so wasn't sure if it merited a walkthru.
Hardest part is just getting the wheel off. Take notes where the spacer, washers, etc are. So it's pretty straight foreword. The rear drum on this bike usually doesn't need replacement unless your over 20,000 miles, but then I've read about folks that don't use the front brake..... :|
Discussion Starter #8
I'm about 28 K miles currently so I was assuming it needed it too (front pads and rotor are all but gone at this point so I'm doing brakes)!
while you've got the back wheel off,its a good time to do a spline lube.
  • Like
Reactions: Orkron
Discussion Starter #10
Followup question:
Front rotors are a nightmare to find... only OEM for $300-$400 each (yikes) and used ones... Is there a good place to find affordable after market front discs for a '92?
Will do! Thanks for the reminder!
not much in aftermarket disks. hell, even rotors from a recycle yard are expensive..
but the ebay is going to be the best bet.
when I tried once to remove one of mine, I found the bolts where 'on there'. I broke an allen socket trying to loosen the first one. as of that point in time, I said they stay on. Note: I was going to remove them prior to my buddy changing out my tire for me, as a precaution during the change. turns out, didnt need to worry, his tire machine did just fine with the rotors still installed
why not go on eBay and just buy a whole wheel with the rotors?if the bearings are good in the new wheel it'll be plug and play,baby.
Discussion Starter #17
Are your rotors warped? Just because they have grooves in them doesn't mean they are bad. I'd spend the money on new (braided) brake lines......
There's like a millimeter or less of surface left... not warped, just worn
...wouldn't that be more money? Especially with shipping omg
trust me,I'm a doctor.go check eBay out.I didn't check rotors,though,but I will
well I checked out rotors on eBay. go take a look.a little cheaper than wheels,l
1 - 20 of 24 Posts
