1 - 19 of 19 Posts
Wareagle1970
Well, now I have a bigger problem... After KM told me that the throttle grip eyelets should be positioned below the handlebars when you go to reattach the throttle cables to the grip, I just went out and noticed that the grip was positioned with the eyelets below the handlebars, but I still could not get the throttle to turn freely. Removed the assembly cover and now the front plastic eyelet as you are sitting on the bike has broken... What the heck am I doing wrong? I did notice the rear throttle cable had a fair amount of slack in it. Tried manually moving the throttle assembly on the right side of the carbs forward and backward, but all that did was tighten and loosen the front throttle cable at the handle bars...
Unfortunately, I do not have our camera with me. I am in NC and my family is still back in MS trying to sell our house...
I really, really need help now. Figured this was going to be a relatively easy task, but has turned into a nightmare... With the bike shop being closed tomorrow, I'm not sure what I can do from here...
** Note. Is the front cable the pull cable and the one closest to you as you are sitting on the bike the push cable, or do I have them backwards?
Wareagle1970
Discussion Starter #4
Sorry again for the multiple threads... Just really need some help on this. Last night I thought my first post didn't go through, so I reposted...
Is there anyway possible that you or anyone else could take some pictures of the throttle cables at full deceleration and as they are installed within the
starter switch assembly (i.e., with the top part of that starter switch assembly removed)?
I wish!.. I am stuck in a a hotel 180 miles away... ment to work on the bike yesterday but biz ran over..UGH...search thru some of the members pics.. I seem to recall some good pics on there.
Wareagle1970
Discussion Starter #6
will look for some pictures on here. Have been trying to google for some pictures, but haven't been successful so far...
Wareagle1970
Discussion Starter #8
do you have the PDF manual? or the Clymer manual?.. I belive they have some good pics of them.
Have the Clymer physical manual. Could not find a picture throughout the manual of how the cables are mounted at full throttle resting position.
I'm really not sure what 'throttle grip eyelets' are or what being asked for or done with these cables, but I'll try to answer based on what I think is going on. By 'throttle grip eyelets' I will assume that these are the connection eyelets for the deceleration and acceleration cables. If that is true, then the rest of this post will also be true.
I just lubed my cables a few weeks ago and on my '06 the cable attachment eyelets face UP. That allows both deceleration and acceleration cables to be pulled up and over the top of the throttle tube as the throttle is rolled on and off.
I don't have pictures, but I'll attempt to paint one;
When standing on the right side of the bike, throttle cables properly installed and the top switch pod cover off (exposing the throttle cables);
Consider the throttle as a clock face:
  • The connection eyelets are at 2 o'clock in normal position.
  • Deceleration cable wraps up over the throttle tube from the left and is clearly visible from about 7 o'clock to 2 o'clock (where the throttle tube connection eyelet is).
  • Acceleration cable is not visible. The acceleration cable connector is visible in the throttle tube connection eyelet.
  • Roll the throttle on and the throttle tube connection eyelets move counterclockwise as the acceleration cable comes into view rolling over the top of the throttle tube.
When sitting on the bike, throttle cables properly installed and the top switch pod cover off (exposing the throttle cables);
  • The deceleration cable is closest to the rider and clearly visible as it runs up and over the throttle tube to the connection eyelet.
  • The acceleration farthest away and not visible.
  • The cable connection eyelets face up and forward, away from the rider, resting on the front portion of the bottom switch pod cover.
  • Roll the throttle on and the deceleration cable will shorten as it is pulled back toward the carbs, the throttle cable connection eyelets move toward the rider and the acceleration cable will come into view as it is pulled up and over the throttle tube.
Not sure if this helps.
Wareagle1970
Discussion Starter #10
pretty good picture you painted. I assume in your next to last bullet that by considering the throttle as a clock you are talking about looking at the throttle from the end of the throttle itself.
As you are sitting on the bike, the acceleration cable goes into the hole on the bottom of the switch assembly closest to the rider, correct? The push or deceleration cable goes in the other hole furthest from the rider?
Sorry for all the rookie questions.
the other way around.
I updated my previous post.
Wareagle1970
Discussion Starter #13
As you are sitting on the bike, the deceleration cable goes into the hole on the bottom of the switch assembly closest to the rider, and the pull or acceleration cable goes in the other hole furthest from the rider?
Since the top eyelet is the broken one (with the eyelets pointed at 2 o'clock as you are looking at the end of your throttle) then I will not be able to do what you suggested earlier, right?
Wareagle1970
Discussion Starter #14
It is getting clearer. from the right side of the bike and the eyelets are at 2 o'clock both cables will wrap around the throttle grip counter clockwise from the right side with the accel. going in the top eyelet and the decel. in the bottom eyelet.
And are you saying that the your 06 has the eyelets pointing straight up or 12 o'clock?
Just to be clear, here is picture of what I'm referring to as throttle tube connection eyelets. This is where the deceleration and acceleration cables connect to the throttle tube. The picture is not from a VN750, but the idea is the same. Note the position of the throttle tube connection eyelets in relationship to the front brake lever; about 2o'clock if looking at it from the right side of the bike.
If these are the eyelets that you have broken, the you need a new throttle tube.
Wareagle1970
Discussion Starter #16
perfect picture... The deceleration eyelet is the one that is broken. Now, from that picture the deceleration cable would wrap around from the left side clockwise over the throttle tube and into the eyelet. The acceleration cable would wrap around from the right counter clockwise and into the eyelet?
Correct.
Wareagle1970
Discussion Starter #18
Thanks Chris. I really appreciate all your help.
1 - 19 of 19 Posts
