1 - 4 of 4 Posts
I just purchased a 1985 VN700 with about 10,000 miles. As the weather turns, I'm just getting to where I can get out and ride. I purcahsed a new battery when I bought the bike and have quickly learned that it's not being charged. Volts to the battery are only about 12.5. I really hope it's not the stator, but while inspecting the R/R I found that it has a lot of deposits on it. I'm going to roll the dice and purchase a new one and mount it externally or remove the GB. Do you think this is the right move?
Before you purchase a new R&R go to Radio Shack and purchase a can of tuner cleaner and a small wire brush. Use them to clean every connection you can find on the bike. You will be surprised how much of a difference cleaning the connections will make.
Also I believe there are instructions on how to test the R&R in the Vulcan Verses.
It would be the right move to either move the R&R or degoat. If you go the degoat route there is a kit at www.scootworks.com for our bikes.
Where in Iowa are you located?
You can check the stator super easy. You take off the left side cover and find the three yellow wires. Those go from the stator to your R/R. Unplug the butt connectors and check the ac voltage between two of the yellow wires at a time while the engine is runnng. When testing you should give it throttle. The voltage should be 50 - 80 volts AC at 4000 rpms. Good Luck
1 - 4 of 4 Posts
