1 - 5 of 5 Posts
knees in the breeze!!!
i have the motor out and the side cover cut already and when i mock up the mod plate to the side cover with the cut out piece on it .
it looks like the stator will not be set inside the rotor as much as it was.
ive seen pics of some people putting in spacers to set the cut out inboard more . not much but just a tad to where it was in the first place
do i need the spacers?
also i seen the plate gets sandwiched between the side cover and the inspection cover , but that sets the inspection cover out away from the side cover the thickness of the mod plate, therefore the stock gasket wont seal
what is the fix for this ??? crapton of rvt? really don't like that idea at all
what about shaving down the bolt hole posts on the side cover to compensate for the mod plate thickness??
ive seen all the pics of peoples mods done and have not noticed anyone with the inspection cover spaced out like im exper.
Chasin' the blacktop
GloryRider put 2 or 3 washers in as spacers actually moving his stator in a tad further inside the housing and allowing clearance for his stator leads to run between the new plate and the stator. You can see what he did here. ( http://www.vn750.com/forum/showthread.php?t=44450&page=11 )
And yes, shaving down the bolt posts works well.
I just read that thread and that's what im looking for lol .
it didn't come up in my searches for some reason. im wondering why he elected to drill out the center holes and go with bolts and nuts vs. using the bolts from the outsid in going into the center piece ?
I can't remember why he did that, I asked him at the time and it made sense. I sent him a message so maybe he'll chime in with the answer.
Hey Tofer,
Glad my thread could help out! I went with the bolts and nuts because there is no way to bolt anything from the outside in... The holes in the stator core aren't threaded so there's nothing to bolt into to hold the stator to the plate if you bolt it from the outside in... The spacer cut from the original inner cover has threaded holes, so running a bolt from the backside of the stator core, screwed into the spacer, then the additional spacing washers (to push the stator inside the rotor more), through the new steel mounting plate, and then finish with loctite nut keeps everything nice and secure.
Let me know if that's unclear at all, or if I misunderstood your question....
1 - 5 of 5 Posts
