1 - 8 of 8 Posts
Newb with a Bullet!
Are they any shorter than the VN750 stock shocks?
My understanding is that the parts are pretty much interchangeable between the bikes. Could the VN700 shocks (if shorter) be used to lower the VN750 a bit?
Anyone know?
The Professor
Same shocks, same length. :beerchug:
On His Lady Vulcan
Theres two ways that you can lower the rear of your bike.
1. Lowering brackets (do a search on here for lots of write ups).
2. Lowering shocks, 11" shocks aught to get you where you wanna be.
GOOD LUCK!!!
Peace:beerchug:
2. Eat alot.
GOOD LUCK!!!
Peace:beerchug:
Fixed it for you...
Newb with a Bullet!
Newb question. Can you do both the shocks and the brackets or do you start hitting the fender on bumps? Maybe it's a stupid question, but you don't know if you don't ask, right?!
i have the 11" shocks, on there lowest/softest setting, they were bottoming out on bumps. adjusted up 1 notch, solved problem, no more bottoming out, smooth ride.
if you did both, youre finder probobly sit on tire. i would go brackets/ stock shock; or just shorter shocks.
Newb with a Bullet!
Discussion Starter #8
Got my Kendas yesterday via UPS. They look great. Will take and post pics when I get a chance.
1 - 8 of 8 Posts
