1 - 10 of 10 Posts
I need a new front tire. The local mom and pop bike repair shop has the Shinko 100 and 110 for the same price - $69.99 with $12 mounting & balance. I'd like to know what you all think if you've done the bigger tire.
I went with the standard size for the front for me, I like the look of a big rear and small front, tires.
Agreed. I like the VN Custom 900.
Concert connoisseur
from all the bikes I seen at the gathering you can tell the bigger one by looking at it. they say it makes your speedo more accurate and I would think you would get a little longer life out of the bigger one as it would rotate less!
HAWK
Pro, Speedo more accurate, better handiling more rubber on the road.
Con, wont fit with a touring fender.
Headbanger/Popes of Hell
yup! that's about it. the bigger front tire is way better on grated roads! you can't go wrong with the bigger front. well, unless you have a "touring fender". I will never go back to the stock size front tire.
Discussion Starter #7
I have a Gold Wing front fender. Wonder if it will fit.
It may not. Be a good idea to measure your clearance.
The only "con" I can think of for the wider tire is the slight increase in rolling resistance , which might drop your mpg figure down a few tenths......
If there is a greater rolling resistance, it comes with a "pro" too, -a larger contact patch for more traction! :smiley_th
Yeah, but you can let air out of your tire and get more rubber on the road...and effect handling and braking the other way.
A bigger tire also adds more unsprung weight...but as you point out, the pros outweigh the cons by having more rubber holding you to the road.
1 - 10 of 10 Posts
