I replaced my stock horns with a set of welo? "maxi sound horns" from harbor freight this week-end. It was an easy hook-up and bolt on (used stock mounting location and connectors). Tested the horns and they sounded fine. This morning when I started up the bike and let it idle while I was getting my helmet on, the horns suddenly started blowing. I switched off the bike and restarted it, about 30 seconds after starting, again the horns started blowing. I tried to jiggle the horn button thinking that it might be stuck but no luck. I cycled the keyswitch once more and the horns came on as soon as I put the key in the on position. I swapped back to the stock horns and they work fine. I had to get to work so I couldn't really troubleshoot. Any ideas on what could cause this?
- Phillip
- Phillip
