1 - 6 of 6 Posts
Been looking online for a rebuild kit(?) for my 98 vn750 and everything I see all seems different from each listing. I've pinpointed where it's leaking fuel, a plastic looking gasket thats gray in color sammiched between two pot-metal pieces. Excuse my ignorance as because I don't know what those two pieces are called. Where the shutoff valve is located, its behind that, a hole the size of a ball point pen tip. It's leaked fuel here and there when idling/running but it's gotten way worse as of late and it is time to rectify said problem before the guzzolene ignites my bike in a blazing ball of fury lol. I'm at my nephew's bday party right now and can post a picture later tonight or when I get off work tomorrow. Any help is appreciated, thanks in advance.
-Dan
Sent from my SM-S120VL using Tapatalk
Discussion Starter #2
*edit*
The "gasket" in question is about 1/16th in thickness, stiff like pastic and gray
-Dan
I bought a K&L rebuild kit off of amazon.
https://www.klsupply.com/images/fuel-petcock-repair-kits_App.pdf shows that part 18-2723 is compatible with VN750 from 1986-2006.
The part is on amazon here https://www.amazon.com/Supply-Fuel-Petcock-Repair-18-2723/dp/B001KO2JRW/ref=sr_1_fkmr0_1?ie=UTF8&qid=1520210831&sr=8-1-fkmr0&keywords=18-2723+k&l
It's $26 and change. Same exact one that I needed for my '85 VN700. The picture on amazon is a generic picture. It comes with a new diaphragm, new o-ring for the selector lever, new gasket that sits behind the selector lever, and a new o-ring where the petcock seals up against the tank. I just rebuilt mine about 2 weeks ago and it works like a champ.
One thing I did that helped was polish all of the surfaces with 800 grit sandpaper. I put it on a piece of glass to make sure it was flat, and got the sandpaper wet. Just like you'd do to get a nice edge on a wood chisel. I put it together the first time and it leaked very slowly. I got all of the mating surfaces to a mirror finish and now they seal up nice.
Awesome, thanks for the info. Sorry for the late reply, been busier than all sin at the shop. Ordering the parts next paycheck and will post pics.
I’m in the same boat you’re in. After riding the Vulcan around the block to shake off the winter blues, I found my Petcock peaking unnecessarily. Atleast the bowls aren’t leaking. The Petcock is a much quicker (read: easier) fix. Let me know how the kit works for you. I will have to get one myself.
1 - 6 of 6 Posts
