1 - 6 of 6 Posts
Discussion Starter · #1 ·
Hi guys, i been looking for new petcock fo my 89, has anybody tried the petcock for vn800, does it fit right on screwholes.
I have read about TW200, but some says there were shortage of gas supply to the carb.
Any insight and suggestions would be great help.
Vn750; 1989; 馃嚨馃嚟
Rebuild the stock one? Kits are available.
The 800s have different part numbers and larger tank, not sure if it will fit.
Always make sure the fuel lines run downward to the carbs.
Discussion Starter · #3 ·
Can't get the kit here in Philippines. I have check over the net that, local online seller here and says that VN800s petcock fit to 750s and other kawasaki bikes. Hope it is, will try to open the old petcock and check if can give some remedy.
I will made an update again if the 800s will fit..
Thanks.
Discussion Starter · #5 ·
1st photo is the one from ebay saying for VN750, the rest are from local online seller here in Philippines saying it is for VN800s.
From the photos, they all looks the same
Product Font Line Tool Engineering
Automotive lighting Tobacco Nickel Font Auto part
Product Font Automotive lighting Motor vehicle Screenshot
It might bolt on, still a single outlet, so you'll have to use a tee on the fuel lines. Looks like it might make the reserve smaller.
Rebuild kit is about $22.
1 - 6 of 6 Posts
