Rotella T4 (conventional) 15W40. 😁Alright, I just wanna know if I should stick with the oil you told me or if should I get OEM Kawasaki 4-cycle engine oil 10W-40.. pretty much same price $34
I must have misunderstood something:I thought I made it clear O’Darkness, it’s Rottella Synthetic. If I can’t find that I’ll use Mobil 1 Synthetic, which is what’s recommended for my Bonneville.
At this point, I understand you use Rotella but if it's unavailable, then Mobile 1. However, which TYPE? As in, which weight? Spockster says he's using a diesel-grade oil. If I knew nothing of oil, all I'd be looking for is Rotella or Mobile 1. Would I just look for a motorcycle specific oil by each brand?I use the synthetic now. Just can’t find the Rottella regular oil around here anymore,
That's much better, thanks! Since we're on the subject:Rottella makes a “regular” petroleum oil AND a synthetic. I said the regular one was hard to find. The synthetic isn’t (as much). The Mobil 1 I look for is 10w40. I think the Rottella synthetic is 15w50.
Both of the Rottella oils are “diesel grade”.
Many started using the regular Rottella because someone back in the mid 80’s ran an extensive test of oils for motorcycles.
The top rated one was the Rottella. The 2nd place went to Mobil 1 (These were both regular oils)
Rottella and Mobil 1 later came out with synthetic oils. Mobil 1 in other testing placed 1st.
Rottella came in 2nd. However Mobil’s oil was almost twice as much, so many continued to buy Rottella.
Since then, others have sworn by their particular choice, e.g. Castrol, Valvoline, Amsoil, etc. None of these are actually bad oils. That’s why any discussion on “what oil to use” is usually met with disdain from veteran riders.
Hope that answers some of your questions 👍
NO WAY?!?! Yikes, I think I better change that oil sooner and check for those flecks. Thanks for the tip!The “filter” is really just a tubular metal screen. I cleaned mine with contact cleaner.
The importance of this for the Vulcans is if your balancers are about to give up the ghost, you’ll find tiny bits of black rubber in the screen when you remove it. If you find some, the fuse has been lit and your only hope is to either replacing the balancers or bury the bike and report it stolen for the insurance money.
When a balancer goes out, it usually causes catastrophic damage to the engine.
So, just a heads up …😉
Bits of clutch material found in the screen is completely normal, these pieces will be thin, flat, flakes.NO WAY?!?! Yikes, I think I better change that oil sooner and check for those flecks. Thanks for the tip!
Do the balancers always go out? Is this a relatively easy thing to address BEFORE it happens?
@Checkered Floor Garage WE NEED A VIDEO!!!!
EDIT: Just did a quick search of the site, and I'm not happy.
