I guess there a several things you may want to look before you get full on the renovation. First I would check the crankcase damage you mention above, can't really tell by the photos but if the damage it's rather small you may be able to get away with it by removing all the sharp edges. Check free play around the bearings in the crankcase to look for extra play. All bent pieces must be replaced so you may want to start making a list of the replacement parts. I would also replace the balancer rubber dampers on the left side damper (stator side) and gaskets may be needed.
The manual should tell you the free lenght of the drive chain for the oil pump you want to check that.
So far that's what comes to mind... uhmmm maybe the piston rings as you have significant mileage on them. You may want to give them a look
Hope this helps
Hope this helps
