I occasionally get an oil light when the engine is cold and the RPM has exceeded about 3k.
I want to check the pressure with a gauge.
Does anyone know the thread size of the sender?
Kawasaki made an adapter (57001-1033) for their oil pressure gauge (57001-164) but I can't find the thread size for those either.
Does anyone know what PSI the switch is supposed to switch at?
The manual specifies 43-51 PSI at 4000 RPM with 90 C degree oil.
I haven't experienced any symptoms of low oil pressure. It only happens when cold and I accidentally get the RPM too high. Coming back to idle, sometimes it goes off after a second, sometimes it takes a crack of the throttle for it to go away. I never see the light once it warms up.
