1 - 5 of 5 Posts
Discussion Starter · #1 ·
With the bike off, the window shows full of oil. When running, the window runs empty. This normal for 4 qts of oil?
Try to idle. It wont. It stalls. It will idle too high, then when I adjust the idle down, it stalls out at 1500rpm.
Throttle will not roll back once it is let go. Throttle cable adjustment required?
Who invented liquid paper and why?
(making a '86 road worthy after sitting in a garage for 13 years...almost done, except for the idling question.)
Thanks
The oil level is correct.
The stalling may be from a hose being off a carb or there is crud in the carbs. Since it has sat for so long I would recommend a carb cleaning / overhaul.
As for the throttle not returning to idle when let go, I would thing that the return spring is broken, linkage is stiff or the cable is binding.
HAWK
Les Nesmond from the Monkeys mom invented Liquid Paper, She was a Secretary
Discussion Starter · #4 ·
Thanks. A hose may be off. I already rebuilt carbs.
1 - 5 of 5 Posts
