1 - 8 of 8 Posts
Discussion Starter · #1 ·
I was just perusing through the Verses (slow day at work) and noticed a note about the VN700's having a different oil filter thread size then the VN750's.
See this thread
Can anyone verfiy this? I just picked up an oil filter and planned on changing the oil this week. I'm pretty sure whatever I bought said it was ghood for the VN700 & VN750.
Thx. :smiley_th
Uber Member
i checked on wix's web site and they said that they use the same filter 51334.... there is a zn700ltd that it may be confused with..... then i took that filter number and went to purolators website, and checked to see which it is in their brand.....
****FYI****
85 vn 700 and 86-93 vn750's use wix 51334
93- current use wix 51358
The VN700 1985 and VN750 Vulcan 1986-1993 has 20 x 1.5mm threads. The following oil filters will fit.
* Purolator PL14459
* Mobil-1 M1-104
* AMSOil SMF 102
* Baldwin B227
* Fram PH6010A
* Hastings LF402
* NAPA 1334
* Purolator L14459
* WIX 51334
I highly recommend one of the first two, highlighted in blue.
The VN750 Vulcan 1994-2003 also has 20 x 1.5mm threads.
Here is a link to an excellent motorcycle website that has oil filter cross references. http://motorcycleinfo.calsci.com/FilterXRef.html
Hope this helps.
:motorcycl
Geek
Now thats a useful link. Put it in the link section !
Benjammin'
3.5 inch oil filter
Anyone use the recommended longer oil filter on thier VN750? I am going to change the ole oil this weekend and wondered if I will have any issues with the longer filter I have. I opted for the SuperTech @ WalMart for much less and suitable filtering.
Thanks!
Ben-
Ben, I have one on my 95 right now and it works great and replaced them at each oil change last year.
Uber Member
i strongly recomend the purolator plus.....It has one of the best filter elements out there on the market. I work for a supplier of airline parts, and that is the primary brand we carry. I switch out my purolator every other change, and it works great. bout 5 bucks at pep boys. i'm not sure about other brands. i know fram has a bad habit of comming apart because of the cardboard they use inside of it.
1 - 8 of 8 Posts
