1 - 3 of 3 Posts
Discussion Starter · #1 · (Edited)
I have what seems to be the very common issue of a leaky final drive that makes a total mess of my rear wheel. Check out the picture below.
Tire Wheel Automotive tire Locking hubs Tread
Per Fergy's Spline Lube Procedure, I ordered O-Ring part number 92055-1044 and it should arrive shortly. Share with me any tips you have for removing and replacing this O-Ring and I'll include that in my Youtube video that I make in the coming weeks. Also, is this the O-Ring that I will be replacing:
Wheel Tire Automotive tire Motor vehicle Tread
Thanks as always, forum. :)
This isn't a tip on replacing the o-ring and it may not apply to your situation but my rear wheel looked exactly like that when I went to tackle my final drive. I don't remember if it was in this forum or elsewhere but someone suggested that it was more likely a case of previously over-lubed spines than a leaky drive. So far, it seems that information was correct. I cleaned everything up and applied a very conservative amount of high-tack red moly and called it good. It's been about 10k miles and no sign of any oil.
Been enjoying your vids, btw!
Discussion Starter · #3 ·
I'm happy that you've been enjoying the videos. I just got a wireless mic from Amazon for $30, so the voice quality will be improved significantly moving forward!
At first, I thought the mess on the rear wheel was due to me over-lubing back in 2020 when I last did the spline lube. But it just leaked constantly for the 13,000 miles since then and never stopped. So I don't think it's that. I wish it were. :)
1 - 3 of 3 Posts
