1 - 14 of 14 Posts
I purchased some new LED turn signals since the all the wiring was screwy and I wanted something a little nicer. I did purchase an EP34 flasher unit. I know the wiring is good because i tested each circuit using the old lights. The new lights are were tested as well. I cannot figure out why they wont turn on.
https://smile.amazon.com/gp/product/B07Y8C34MP/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 (rear turn signals)
https://smile.amazon.com/gp/product/B0786CX8LP/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 (ep34 flasher unit)
https://smile.amazon.com/gp/product/B07J55W1N8/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 (front turn signals)
Start with the silly stuff, Like checking for bad connections. The new lights should still work with the old relay but they’ll just rapidly flash almost like a strobe. You said you tested them first, how’d you do the testing?
Is the polarity reversed? LEDs won't work if the polarity isn't correct, like an incandescent will.
Ok well that confirms the lights work but doesn't say much for the bikes wiring. I remember your other post stating that the previous owner had spliced in the DRL, so are you saying you have no power to the new lights when hooked up?
Discussion Starter #10
correct, but when i wire up the old lights I do. the actual circuit is providing power, there is something about the LEDs the bike doesn't like. Everything works separately.
im not using LED bulbs, these are wired directly
Thread title says LED. And you installed the EP34?
Swap positive/negative on one and see if the light works.
Grounds on this bike are black/yellow stripe.
1 - 14 of 14 Posts
