1 - 3 of 3 Posts
I just bought a new battery maintainer from harbor freight. It came with brackets to permanatly install it. I decided to mount it on the left side, under the cover, in front of the junction box. I put a bolt through the screw hole for the bottom of the cover and tightened it down, then slid the charger bracket onto it and tightened it down with a nut. There is enough bolt sticking out so that i can use a wing nut or something similar and secure the bottom of the cover so it doesnt blow off. It only cost 20 bucks, and it is the 3 stage charger that all the AGM typer batteries require. I have it charging the battery now, it was really low, I will keep you all posted on how it works and put some pics up of the finished product.
Charger
Hi Diamondjim:
I have one of those chargers, and it has worked well for me. I made some leads with bullet connectors that I tuck under the seat while riding, and alligator clips that slide into the female bullets are on the charger. I just hook up when I'm not going to ride for a few days.
I did not want to attach it to the bike. I don't know if the vibration and heat might kill one of the chinese things. I bet yours will work fine though.
Thanks for your service Marine. We owe you!
Bronson
Discussion Starter #3 (Edited)
So as promised, here is an update on the charger with pics. The charger works great, it brought my old wet cell battery back to life, altough i am planning on purchasing an AGM battery in the near future. But since I cant ridie it right now, its not a huge deal as its not run that often. But it works great, and the side cover fits right over it, you cant even tell its there with the cover on.
1 - 3 of 3 Posts
