1 - 15 of 15 Posts
What do you guys think?
HAWK
Look nice.
I like them, sharp looking bike.
Jon
I like the diamond plate and the expanded metal. Very nice.
Uber Member
very nice.... makes me wanna change mine.....
Looks good :smiley_th
I have some diamond plate sittin' around from some truck running boards that I almost used to make a replacement toolbox.
But I kinda like the small backpack I put there. Maybe I'll do something like that with the pieces instead.
Discussion Starter #11
Thanks for the replies and input, glad you guys like um.
As most of you already know , I made them, wasnt hard to do.
I will explain how, but first to awnser your questions about the crash bar. They came off a 82 kaw 550 LTD I have, They were on that bike when I bought it, Believe they were a universal application.
The bottom mounts lined right up with the frame bolts on the vn750, no problem there, The top ends of bar are mounted using 2- U-bolts, This was a nightmare installing because the middle frame bar was in the way,I worked those U-bolts for about 3 hours to get them on.Also I had to cut down plastic frame covers in front of the tank,no big deal there,used a good pair of tin snips, cleaned it up with dremel.The floor boards I got off the net for $130 dollars, they are 1"1/4 Universal application,very comfortable.
Now for the ears, materials used: 1 sheet carbon fiber (ebay store,about $30 dollars, credit here gos to another ebay member that did this first with the carbon fiber,cant remember name. 1 piece of stainless steel mesh (ebay store,about $15 dollars,store name :grill king. 1 piece of thin diamond plate
alluminum .035mm thick,very workable,store name: cutsmetal. finally, a small box of chrome plated bolts from local dealer, about $3 dollars,and replaced stock bolts.
First I removed black insert in air box cover from behind,they pop right out.
I then used this as a template to cut carbon fiber and stainless steel mesh.
I bought carbon fiber with 3m backing,so I stuck them right on,The steel mesh I secured using a small bead of clear silicone along the outer edge inside of inset space.I used a pair of tin snips to cut all these materials,also used snips on diamond plate. Then cleaned up edges with a dremel (high speed rotary tool). The diamond plate band I made is secured at bottom with 4- alluminum pop ribits at the seam.
If you guys have any other questions Ill be happy to replie. Steve A.K.A Spriddle
Uber Member
is that steel mesh on the radiator too? i like the idea, i want that on mine. i wont copy you, i'll find something else but i like the overall idea....highway hawk crome radiator shroud with that steel mesh would look killer.....
Discussion Starter #13
Yep,thats Stainless steel mesh from an ebay store,$15 Bucks,really improves the
look of the rad. Dont mind anyone copying anything I've done.:rockon:
Avid Rider
Yep, very nice work, spriddle, thx for sharing that.
1 - 15 of 15 Posts
