My pick up coil broke near the magnet as I was replacing my stator. Does anyone have a working one I can buy? It has 2 magnet heads and a long cable, sits near the stator case. Similar to the picture attached but longer cables.
What year is your bike?My pick up coil broke near the magnet as I was replacing my stator. Does anyone have a working one I can buy? It has 2 magnet heads and a long cable, sits near the stator case. Similar to the picture attached but longer cables.
It is a 2001. All the listings I am seeing are more expensive, the only ones cheaper seem to be for different bikes.. can you post a link to what you’re seeing for cheaper? ThanksWhat year is your bike?
I found the OEM part number. It is 59026-1062
A quick Google search yields some results less than $50. From what I've been told, everything from '86 to '06 is fairly interchangeable, but I could be wrong.
You're right, some of them are listed as belonging to other bikes, but since the part number is the same, you should be able to use them. Also, maybe you should check out Easyrider750's post here.It is a 2001. All the listings I am seeing are more expensive, the only ones cheaper seem to be for different bikes.. can you post a link to what you’re seeing for cheaper? Thanks
