1 - 2 of 2 Posts
Discussion Starter · #1 ·
Hi!
Can anyone tell me the hose connected the gas tank under the seat, there's a clamp on it , I want to know where did it connect to the other side of it? It's other nozzle is flattened by heat
Thank you!
Hi Jason,
If you just have one connection point at the back of the tank, then the hose connected to it just hangs straight down through the frame of the bike. It is a vent tube that drains to below the rider so if the gas tank is too full and gasoline comes out of it while you are riding, it will drain to the ground and not onto your lap.
1 - 2 of 2 Posts
