1 - 6 of 6 Posts
Looking for someone parting out a 97 vn750 engine.
I need the rear cam shafts from each cylinder and a couple of rocker arms.
Trying to get my bike back together and running.
Also may need a couple of coolant system parts, but not sure yet, till i get the engine back in the bike.
The Professor
So you need the front intake cam and the rear exhaust cam, correct?
If the rockers and cam lobe were chewed up you will also need to replace the lash adjusters.
Simple Solutions
or 2 exhast cams because the engin was turned to work on the other cylinder??
The Professor
If they have that way of thinking they are to stupid to repair an engine!!!
You should always reference an engine as it sits installed.
Rear cam on front cylinder is INTAKE, rear cam on rear cylinder is EXHAUST.
Discussion Starter #5 (Edited)
Cams
lance328
Yes thats correct the intake for front cyl and exhaust for the rear cyl. those are the ones that are worn. The lifters are ok, but i have one rocker arm that has worn through the chrome and needs replaced.
:smiley_th
The Professor
lance328
:smiley_th
Contact Crobins365 she should have the parts.
1 - 6 of 6 Posts
