1 - 4 of 4 Posts
So I've converted to a single carb setup using a mikuni vm38. Shes a tad rich but seems to be running good. That manifold sits so shallow that the slide happens to be directly under the tank causing a clearance issue for the throttle cable. Short of that Ive got the conversion done
https://m.youtube.com/watch?v=4wsKx21ObdE
Didn't get to see much of the carb setup, but it sounds like it's running well.
Is that a velocity stack or an air filter?
The manifold isn't too pretty looking but it's sealed up. Yes it's a cheap velocity stack from eBay. When I get a chance I will post some pics of the manifold. It's made by searayguy123 on ebay
Thank you, danielrocks21. i used your conversion as reference and i've been enjoying my vn750 for more than two years now...
1 - 4 of 4 Posts
