1 - 14 of 14 Posts
Ok, so since I've been registered to this forum as of an hour ago, I have made several references to my chopper build. Here's my grand scheme for the build. The bones of the build is a 1988 VN750. The engine is coming out of a 2001 VN750. The bike as I bought it was a rolling chasis for $26 with a title. The parts bike that I have the engine from I got for $100 without a title. It was also a rolling chasis. So all I've got are the frame, the engine, most of the front and rear ends, the transmission, and the final drive. The general idea: custom purple and white paint job (including rims, exhaust, and engine), single carb conversion, plus 5" fork tubes, -1" rear suspension, modification to a single spine, peanut tank, and apes, deleting all of the extra sensors and other crap to make is as simple and clean as possible...I can't wait to get it done!
Might be ok if the geometry comes out right. Think I would keep the carbs and just learn them, unless making the manifold is a strong point for you.
How many carbs do you have? I'll take any you don't need if you do the single.
Singles often end up sticking out too far to the side, and fabricating the manifold can be tricky.
I have 0 carbs, lol...there is a guy who makes the manifold for $175 and I'm getting the Harley carb for free.
Zero carbs, that's like some nasty lite beer. 🙂 I assumed all those bikes were complete. Wonder where all the carbs went 😄
Hard to beat free!
Discussion Starter #5 (Edited)
I have 0 carbs, lol...there is a guy who makes the manifold for $175 and I'm getting the Harley carb for free.[/QUOTE]
Hard to beat free![/QUOTE]
Yeah...none of the bikes were close to complete... But I am excited about the single carb...I'll have all manner of air intakes to choose from by going Harley. One of my friends convinced me to commission a custom triple tree...thinking I'll go with 49mm fork tubes...damn...this just got expensive.
49mm? Fatboy forks? 🙂
We like pics here, keep us posted.
Will just adding longer forks make the geometry work? I'm asking because I have no idea. But I know how the wrong setup can take you for a ride.
He will still have to rake the neck to make the geometry work. I wonder if he will be doing away with the front disk brakes? I wouldn't trust relying solely on the rear drum too much
Discussion Starter #9
Keeping the front brakes, lol. I like being able to stop.
The steering head will have to be raked to keep the steering geometry useable with extended forks. And it will handle poorly. Kind of like a wheelbarrow. I wouldn't trust anyone but a professional frame builder to do the frame work. There is a tremendous amount of stress on the steering head, and there will be even more with a raked out front end. You can use just a single front disc brake on the front wheel, I have done it on a stock VN750 for 100,000 miles. Or better yet, it would be nice if you could find a front wheel with a drum brake. There is nothing wrong with a drum brake, as long as it is in the front. Dual discs in the rear would be worthless without a front brake.
I love the idea of a single carb, but I have yet to see a singe carb manifold for the Vulcan 750 that I would use. I actually like the idea of a carb/air cleaner sticking way out on the right side, I have considered putting such an air cleaner on my Sportster 1200.
Amen to that. My cousin is looking to build a chopper out of his 883. He wants to put the 1253 (can’t remember the exact cc, doesn’t matter) kit in it that’ll bring to around 135hp. He also wants to do away with the front brakes and install the suicide shifter. I’ve told him, but he won’t listen.
He'll listen after the first panic stop...
Sent from my A501DL using Tapatalk
1 - 14 of 14 Posts
