1 - 1 of 1 Posts
Undercover Sportbiker
Apologies if this is a repost. Got this off another forum and fiugured I'd pass it on to all.
Motorcycle Clothing Survey
"The Gear Up! Project has just put up a short survey to help manufacturers, safety organizations, and the Gear Up! Project to better understand the choices you've made when it comes to safety gear.
With your help, manufacturers will be encouraged to make more of the good looking, comfortable, and safe gear that you'll be most likely to wear.
Please take a couple minutes to fill this out, and, if you're on any other forums, consider encouraging the readers there to fill it out too. The more responses we get the more accurate the data will be.
Thanks in advance."
http://www.gearupproject.org/survey.html
1 - 1 of 1 Posts
