1 - 6 of 6 Posts
Retired USAF (IYAAYAS)
I have a luggage rack coming in the next few days but the bolts are not included. Anyone know the specific info on what bolt sizes I'll need to get?
The 2 main bolts are 8-1.25 x 20mm that hold it down. You'll probably need (2) 5/16 flat washers and 2 split lock washers to go along with them.
If your 4 bolts that go into either side seem a little short just take them to the hardware store and get them 5mm longer. Not quite sure what size those are.
I should have done that, but no, I went and got regular bolts. Whenever the next time is that I have a need to remove the rack, for whatever reason, I'll swap over to Allen heads. It'll make getting to the lower bolts much easier.
I suggest replacing the side bolts with Allen heads. Makes life easier installing ....
boltdepot.com is a good place to deal with, i use them to convert everything over to allen head whenever i can
  • Like
Reactions: Gaz73
1 - 6 of 6 Posts
