1 - 9 of 9 Posts
Ratbiker
Added 11" shocks to my bike as part of my ongoing (slowly) bobber project and found something I wasn't expecting. I took a right turn through an intersection and really leaned the bike over scraping the peg. That wasn't unexpected. When I got to work I made a sharp left turn leaning the bike and got a much more jarring grounding.
A friend and I went out to the parking lot and we held the bike down at an angle and I realize that the bracket for the kickstand that's welded to the frame is what scraped. That's obviously a lot more dangerous than scraping pegs. I had it leaned into a lefthander at 60mph this morning but I guess I don't lean as much at speed as I do in 2nd gear.
I think I'll look at the kickstand bracket to see if I can grind any material off safely. Anyone else noticed this?
BTW, The shocks I bought are the MDI/Forsa ones, much cheaper than Progressives and although obviously stiffer than stock they gave me no handling issues. I got them at the link below. Took two days to ship across country, they're the cheapest place i found, AND I got two free jawbreakers. :D
http://www.tasclassicmotorsports.com
what did you do buy the last set? Where are they located?
Ratbiker
Not sure I understand the question. I bought the shocks from the folks in the link I posted. They're in Indiana. The previous shocks were the stock ones.
Don't need you to be doing an "Old Dog" into someone's yard! Be really careful while you're figuring out how the bike's gona handle after all the mods. That KZ1000P I had was a tall seater, and lots of folks on the KZP yahoo group was always talking about how to lower the bike. At stock height, I wuz always dragging the floorboards on sharp turns. I saw many threads talking about lowering where the guru's were warning about getting the suspension any lower causing dangerous problems... Just be careful man!
Ratbiker
I hear yah. Too old with too many dependents to do anything stupid. :D
I'll watch out for it until I can figure out if the kickstand mount can be suitably modified. Otherwise I'll try maxing out the shock height, although that defeats the purpose a little..
Was the purpose because you are "verticaly challenged"?
Did you lower the front end along with the rear?
Seems like the centerstand would touch before the kickstant mount..or at very least the kickstand itself.
You could try putting more preload on the shocks ... or just try taking it a bit easy in those turns. If you want to scrape parts perhaps you should get a bike more suited to carving up twisty roads.
You can add a longer bolt to the footpegs "feeler" so at least that would hit before something solid.
Lowering the bike usualy ends up as a comprimise, you can't have your cake and eat it too as they say...........
they have no more on hand is why I asked if you bought the last set and you answered the other question about them being located in Indiana,That is aneat site got a ton of obsolete stuff on there,I am getting ready to start on an old 1972 CB 750 SOHC and that bike of the month gives me some ideas.
Ratbiker
Discussion Starter #8
The purpose was to make the bob project look cooler is all. :D
We held the bike over at an angle and the kickstand mount has a piece that sticks out lower than the kick or center stands. Didn't lower the front.
I do realize that the stock bike is pretty sporty for a cruiser and I'm pushing myself into a compromise. Funny, I did think about adding longer bolts under the footpegs. :D
For now I stiffened the shocks which lifts the rear almost an inch and I'm cornering with relative caution, at least in left turns. :D Dammit, I want my cake!!!!!
I would email them. The site said they were out but they had a set. At least they should be able to tell you when they will get more in. You won't find them cheaper.
Ratbiker
Discussion Starter #9 (Edited)
Checked more accurately and the kickstand nub is higher than the pegs. I ground it off anyway. I must've hit a high spot on the road. Went for a ride to the coast at the weekend and the pegs scrape too easily set to their lowest so I've jacked the rear back up a half inch which seems like enough. Next I'll remove the center stand to stop it scraping when I hit the sidewalk entering my driveway. It should be a quick refit sans spring for oil changes etc. and grounding the stand means I'm putting load onto the exhaust. :O
1 - 9 of 9 Posts
