1 - 13 of 13 Posts
knees in the breeze!!!
ok so i have a analog volt meter on my bike and a while back i was seeing readings of 13.5 to 14 volts while running down the road
and now im seeing 12.3
the only electrical thing i have done is to move blue wire in harness bypassing headlight relay as my light wasnt working
i tested the volts on the batt and i have
12.2v just sitting
12.4v at 4k rpms
im not sure where to go from here but im afraid the stator is going
any ideas??
It takes 13+ volts to maintain/charge a 12 volt battery. 12 volt is minimal and should be 12.7 volts on a fully charged battery. SO, what I'm saying is at 12.4 you ain't charging. Test the stator at the connections behind the engine and if all goes well move to the R/R. Could be bad connection at the r/r.
ok so what is the best way to do the checks?
should i use the charging system sticky at the top of this section ?
romeobravo172
Try un-doing what you did, moving the blue wire back to where it was and re-test, Just a thought!!
yeah thats my first move but then i dont have a headlight lol
Discussion Starter #7
cant print but got me a notebook to write it down
Discussion Starter #8
firsttests=
i put the blue wire back in stock position and
key off = 12.47v
at idle= 12.37v
at 4k = 12.56v and slowly climbing
did headlight relay bypass and
key off =12.5v
idle = 12.18v
4k = 12.3v
i figured the v would be lower as now the headlight is on
Discussion Starter #9
second test
res to ground in ohms
from stator legs to frame
leg a =.2
leg b = .5
leg c= .6
Discussion Starter #10
ok 3rd test
stator ac voltage
at idle legs
a to b = 4.54v
a to c = 15.45v
b to c = 16.5v
at 3k legs
a to b= 9.39v
a to c =42.2v
b to c = 40 .8v
uh oh!
Discussion Starter #11
retested and results are consistant with the first time maybe a v or 2 off but still one leg is super low
Discussion Starter #12
1 - 13 of 13 Posts
