on the right hand side of the bike sort of under the battery compartment but on the outside of the bike there is a small tank with a level of high and low. What is that tank for?
Blessings!
Rich
Blessings!
Rich
Top it off with coolant that says on the bottle that it is for use in ALUMINUM engines. This is a good one. Make sure all your antifreeze in your engine is this type.That would be your coolant reservoir. Top it of with a 50/50 mix if needed
Not agreeing or disagreeing but Ma Kaw has a special notice in the manual to check it cold.Um, don't "top it off" when the bikes cold. You'll end up overfiowing coolant on the ground. Go for a ride and check it after the bike heats up. Just make sure the level then is between the full and low marks.
Am guessing you never had a water-cooled bike before?
