1 - 14 of 14 Posts
Hey guys, long time lurker here but thanks for all the help so far!
My bike at the end of last season started to develop what sounds like fairly loud lifter tick along with alternator whine coming from what I can tell is the right/front side of the motor. I changed the oil/filter at the start of this season and didn't find any debris or anything else concerning in the oil screen and haven't felt any unusual vibration.
The alternator whine is most noticeably present while driving, and goes away as I come to a stop and the rpms come down, though it isn't linked solely to moving. This leads me to suspect it is not in the drivetrain/axles.
The lifter tick also is noticeable as I'm coming to a stop/downshifting but usually goes away shortly after stopping as the rpms come down.
I haven't noticed any change in either noise after I changed the oil and started riding this season, if anything it is getting worse slightly. It doesn't sound like rod knock and I haven't noticed any metal in the oil, so I'm hoping it's not that.
I haven't had a chance to test the R/R and stator yet, is there anything else I should be looking at?
Thanks!
-Steve
Do the grambo trick on the front cylinder acct. Go to the vulcan verses for specific instructions.
james
james
Thanks, yeah I was just reading up about the ACCT's sticking and causing things to clack around. I will give that a shot after work and see if that helps.
-Steve
Discussion Starter #4
Did the grambo trick on the front cylinder, seemed to keep the tick away on the ride home. The whine is very noticeable btw. With a helmet, ear plugs, drilled baffles and degoat I can clearly hear it when it starts whining under 3k rpm, then the exhaust just drowns it out. It seems to change tone occasionally but not in relation to rpm/gear/road speed, and on my drive home would only happen while I was moving. Just before I would come to a stop, it would stop also.
I suppose the whine could appear to come from the opposite (right) side of the engine, but the stator/alternator is on the left side.:confused:
I`m not sure what to make of the whine, but don`t quite yet get locked in to thinking it HAS to be the alternator.
How old is your bike, and how many miles?
Mine has a whine in it, but it's coming from the rear of the bike. I thought it was coming from the front, but as I listened, it was coming from the final drive, especially when I let off the throttle.
As for the whine coming from the right side, the only thing that I can think of would be either the water pump, or oil pump, or possibly the clutch.
Next time you hear it, pull in the clutch, and see if it goes away, or quiets down.
Just a thought.
Discussion Starter #8
Thanks for the input guys. I'm definitely not assuming it's something electrical, that's just what it sounds like if you've ever heard a fried alternator.
The bike is an '86 and the frame/etc has about 14k miles on it. The motor was swapped by the previous owner so I'm not exactly sure how many miles are on it, he got it used off ebay I think. If I remember what he said it wasn't substantially more or less than the current mileage on the bike, he's a good friend of mine so I'm not worried that it has a pile of miles or anything.
As for the clutch: The whine will sometimes come and go while I'm riding down the street at random. Sometimes I will come up to a stop and it won't be making the noise, and while I'm sitting at the light it will start up again. Gear/throttle/clutch don't seem to affect it. I haven't had a lot of time to troubleshoot anything just yet, I'm hoping to at least do the continuity check on the stator this afternoon/tonight and will report back my results.
I relubed the shaft splines about a year ago with the honda moly60 paste (and plenty of it at that). I changed the rear diff fluid at the same time, along with redoing the fork seals completely (were leaking). I also did a custom homemade ear shave out of some aluminum plates I cut to fit and completely removed all the lines for them going to the airbox and plugged that hole on the bottom. I cleaned the carbs and also installed iridium spark plugs and a MF battery. I also have recently balanced the carbs and adjusted the idle mix screws out about 2.5 turns to richen it up a little. The kickstand switch was acting up and causing the bike to want to shut off/cut out while riding so I cleaned that out as well.
As you can see I've already done a ton of maintenance to this bike from when I got it. I'm hoping I don't have to do a stator job! =D
-Steve
:worthless
Without pictures it never happened. lol
Discussion Starter #10
Oops, sorry I meant to say coastered with some homemade aluminum blockoffs, not an earshave! My bad, I was typing fast when I posted that...
Discussion Starter #11
Ok, so here goes.
I tried unplugging/cleaning several of the bikes electrical plugs/contacts the other night including the r/r. The bike does not want to turn on the headlight now.....and yes everything is cleaned off and back in the right spots. It fired briefly when I cranked it the morning after cleaning all the contacts, but then shut back off shortly into my ride.
I checked the 3 yellow leads coming out of the stator for resistance. Between all combinations of leads it read ~0.8 ohms. At the 6-pin plug testing all combinations it read infinity on the r/r. This seems to mean the r/r is toast...? Maybe I wasn't checking the proper wires. I was testing the wires actually coming out of the r/r not the other plug that is part of the wiring harness.
The battery voltage with the bike off is about 12.7v, with the key on bike not running is about 12.4v, with the bike started and running at ~3k rpm is about 14.7v all measured at the battery.
The whine I have noticed now only happens while the bike is cold and while I am moving. Just before I come to a stop (while still rolling slowly) it will stop the noise. I can start the bike up on the kickstand, put it in gear, and let the clutch out and haven't noticed the noise, but I have only tested this while the bike is warm.
Discussion Starter #12
Alright, so I got the headlight working again. Guess I had a corroded connection at the junction box. I pulled off the two multi-connectors and the blades on the junction box were all pretty corroded/greenish looking. I took the wirewheel for my dremel to them and packed the multi-connectors up with dielectric grease and that apparently solved the problem, headlight turned right on when I cranked it back up. Still trying to figure out where that whine is coming from though.
-Steve
I have been riding mine these last few days, and the whine in mine is definitely coming from the final drive especially when I get out of the throttle. I will listen to mine and see if it goes away after warming up a little while then let you know.
Discussion Starter #14
Just wanted to update my thread. I believe I found the answer to my squeel problem. I pulled the speedometer cable totally off the bike and took it for a ride cold to see if I could recreate the problem. The bike was totally quiet for the whole time I rode which for the last couple weeks had been a guaranteed loud squeel. Thanks again, if it comes back after I grease up the speedo cable I'll let you guys know.
-Steve
1 - 14 of 14 Posts
