1 - 15 of 15 Posts
Discussion Starter · #1 ·
I had a liscense plate crack across the top from vibration and wind. After getting a new plate, I decided to reinforce it with a metal frame.
Well, here is that frame now!
Wood Bumper Automotive exterior Rectangle Gas
Any ideas how you are supposed to keep the plate and frames from cracking?
Happy Thanksgiving!
  • Like
Reactions: Vulcan_Frank_750
Happy Thanksgiving!
There's been some posts about plates cracking. Is your engine vibrating more than usual?
Your frame looks like a flat piece of metal, maybe one that's been stamped will hold up better. The one I'm using is chromed and stamped, so the back side is a concave shape. Chrome may also add some strength.
I've never broken a plate, got the frame so I could mount turn signals on the plate.
I use a backer plate cut from an old aluminum sign. Eliminated all the cracking. I used to make and sell them for a few bucks until the postage got to $6 to mail them.
  • Like
Reactions: dirtrack650
Ditto on what flitecontrol said. I had a corner break off of my plate almost immediately after getting the bike, so I cut a rectangle backer out of steel and bolted them together at all four corners. Haven't had a problem since. Since it is a backer, it can be solid and you don't have to worry about a thin edged frame snapping.
Happy Thanksgiving!
Fixed your spelling in the title for you. You're welcome! 😂🤣😂
Discussion Starter · #10 ·
This is the backside of the frame. It was decently thick. It's a cheap Chinese piece.
Rectangle Wood Wood stain Hardwood Font
Looks to be the same shape. I can't tell if that's cast or stamped. The other side looks flat, so maybe it's cast? A stamped piece should be stronger.
My turn signal bracket is mounted on the two top bolts, so maybe an extra plate will help stiffen it up. I used aluminum to make the bracket. Probably anything is better than nothing.
I’d just make a backer plate with 1/8 steel plate, strong but you can still cut it fairly easily with a metal jigsaw blade. That with some washers/bushings should dampen the vibration enough. Then you can use any trim you want.
1 - 15 of 15 Posts
