1 - 7 of 7 Posts
One of my tail light bulbs is out. I have an LED bulb to replace it but want to know if I can do that without modification. I heard you can't on the front bulb and am concerned with the r/r's ability to dispatch excess heat to keep the stator healthy. Should I just get a regular bulb or use the LEd o have?
putting in an LED will cause rapid flashing of the turn signal. replace the stock flasher unit with an EP34 and all good (plug in, no modifications)
What about the brake lights?
No problem changing those. I bought some cheap ones, not as bright as the incandescent. The cheap LED license plate light is nice and bright.
I can tell the previous owner had LED signals. Really small bell wire, single strand, dead-ended near the signals. And it already has the EP34 flasher.
I had no problem changing signal,riding,brake lights,just change the flasher EP34. I think you could o back to incandescent with that flasher,too?
Yes, mine has the EP34 and all incandescent signals.
As far as turn signals, the rear ones don't really draw enough current to make a difference since they are almost never on. The front ones contain running lights, which are on all the time. I doubt switching to LEDs will make any difference as far as the stator is concerned, I just prefer incandescent for everything but the headlight. I wish you could get a rear turn signal running light conversion kit with red lenses. I have one on my Sportster. So I have both the tail light and rear turn signals on all the time. Better visibility from the rear. It is illegal to have any amber light showing from the rear except turn signals. I put a cutoff switch on my headlight high beam, so I can turn my headlight off in the daytime when I use my electric gloves to avoid overloading the electrical system and running the battery down.
1 - 7 of 7 Posts
