I found a set of driver foot pegs from Kuryaken that I want, but they require a splined adapter. I was wondering has anyone replaced their stock driver pegs with kury pegs that required the splined adapter? and if so which splined adapter did you use?
Cruisercustomizing.com says that the KY-8802 will only work for 2003 vn750, but that is for the regular adapter not the splined, and it also doesn't specify driver or passenger.
Just wanted to run it past you guys before I gave up.
