1 - 13 of 13 Posts
Hey all,
I know this must have been addressed before. I just can't find it. I have new Iridiums in my '87 VN 750. They are gapped wide at .036(?) or whatever the widest gap is. She doesn't want to cold start worth a damn. And this is on top of a new MF Battery. Is that too wide for a cold natured bike? Should I narrow the gap? Please lemme know!! Thanks!
BTW- Bullwinkle! I got the bags on and they look great! Pics to come!!
:motorcycl Zach
You've got me thinking now. I put some in mine last night. The book says 0.8-0.9mm. Which works out to be 31-35 thou. Mine were midway at 0.85mm straight out of the box. So I left them at that.
I'm changing the leads as well, so I'll have to wait until I've refitted the rear coil till I start it up.
Regards
Be careful checking/changing the gap on those skinny electrode Iridium plugs. The can break pretty easy. It used to be widely suggested to leave 'em alone because of it, however it can be done, carefully.
All the posts I have read about the iridiums show they should be .032. However, I don't have iridiums in my bike (yet); so if you have to adjust follow 750Doug's advice.
Discussion Starter #5 (Edited)
I was thinking I had heard something about narrowing the gap for cold starting bikes but I can't find it now. What is the best way to resize the gap? I have the gapping ring. I used it to widen them. I would go to the slim side and pull up with it so as not to damage the plug. I guess I would just press the top of the plug against a hard smooth surface to narrow the gap and then recheck?
Honestly, the old plugs she came with were at ~0.032 when I removed them. However, some posts here on the plugs suggested a range from ~0.032 to 0.036. I just want to make the most of my investment in plugs and MF Battery. Thanks!!
Also, I fear I may be on the way to a new starter as this one has a SWEET SPOT developing where sometimes I have to have it turned and pressed JUUUST RIGHT to get power.... :-(
But my baby is a little over 22 years old. May just be how she is. Just a BIT testy.
Like I stated, my experience with the iridium plugs is nil. I would wait for one of the more experienced members to chime in with a safe way to close the gap so as to not break the electrode or tab. If not I would PM one of them and ask.
The plugs should have come pre-gapped, but I checked mine anyway and they were within spec. (0.035 I believe)
You can bend the outer electrode, you just need to be carefull.
Iridiums by nature will give a hotter spark, (even gapped at 0.036) so I would guess your cold starting problem had nothing to do with the spark plugs anyway, perhaps you need to clean the choke?
I really serious doubt that a .002 difference in the gap is going to make your bike start any easier.
Hit the starter as you open the choke all the way. It might not start right off, but should by the 2nd attempt. If it takes more that 4 tries you likely have a carb issue.
ExNewbie..Still Learnin'!
Grimm - I'm having the same trouble but was told by Dianna that she had it as well, so she pulled her starter, opened it up and found that it was full of gunk. She cleaned it thoroughly and problem went bye-bye. :beerchug: Haven't cleaned mine yet but planning to do so soon. Worth a shot to save some major $$$ for a new one. :rockon:
Discussion Starter #9 (Edited)
What you would suggest as a carb problem if the bike seems to run fine and smooth otherwise? She has plenty of power and pick up. She also runs very smooth. No clunking or chugging that I have noticed. She sounds good, too. The cranking issue is sporadic. She has a brand new MF Battery, too.
Any tutorials or suggestions on cleaning the choke?? I love projects!!!
Again, I have noticed an issue with the ignition. I sometimes have to have the key turned and pressed in JUUUUST right to get power when she's in the on position. She has a developing SWEET SPOT. Anything I can do or should do about that??
Thanks!
Discussion Starter #10 (Edited)
Any tutorials or suggestions on pulling the starter?? I have a free weekend starting tomorrow!!
I have noticed that sometimes when she is being diffcult to start that when she does get going FINALLY that she seems to run choppy or sluggish for a few minutes at idle almost like she's flooded but the smell is more of a hard to describe machine smell but not really gas like you'd expect. Typically, in these cases I have to rev the throttle while pressing the ignition to get a sputtery start and die and repeat until she cranks and stays. Then I choke for a bit.
Should have titled this "Starting Trouble..."
The Reanimater
You must be thinking of the Pick-up Coil Regapping for Cold starters.
I was thinking I had heard something about narrowing the gap for cold starting bikes but I can't find it now. .
Discussion Starter #13 (Edited)
Probably not, sir. B/c I have NO idea what that is! hahaah! Sorry. I am still a newb.
BTW- She fires right up with full choke. Like a CHAMP! I was not using the choke and was instead feathering the throttle to crank... I didn't know better.
1 - 13 of 13 Posts
