Yes, it goes away as soon as I crack the throttle.I hear valve train noise, if it goes away as soon as you crack the throttle, I wouldn’t worry about it.
There's not quite 10k on it. When I bought it about a year ago, it had 8500 miles and I've added about a thousand miles to that. Without looking at the odometer, I think it's at 9400-ish.Sounds like an intermittent jack hammer thats very far away. How many miles are on the bike? From my own experience and research I've seen that the ACCT's usually need to be replaced between 15k and 25k +/-. I was at 26k when mine started making very very slight noises, so I just changed them out for the MCCT's. But this is a sound I've never heard before on a Vulcan or any other ICE for that matter.
I'm inclined to think that if it were a spark plug wire arcing, it would be affecting the running of the engine. I saw no fluctuation or noticeable irregularities in the rpm gauge.Does sound like a rocker arm, like maybe a lifter bleeds off a bit, briefly, or a valve is getting sticky. Seafoam in the oil can free sticky lifters and valves.
It's not a spark plug wire arcing, is it? Sounds more metallic I think.
Since it has two spark plugs per cylinder, you wouldn't see much change if one is arcing, mine didn't change when it was arcing.I'm inclined to think that if it were a spark plug wire arcing, it would be affecting the running of the engine. I saw no fluctuation or noticeable irregularities in the rpm gauge.
I don't know if I'm connecting invisible dots, but it seems like this has only begun once the weather became colder.
I've also noticed that if I ride around for a few minutes, and then park it again and let it resume idling, it seems to disappear.
Definitely something I've never encountered before.
They sound different to me as well. However the OP's engine sounds like it is running at a bit faster RPM than the 2nd example. The last one is the sound I recognize as it clearly is RPM related. The 1st engine sounds really fast and I also think it sounds a little electrical in nature. ( Like a set of contacts opening and closing real fast, but I do not understand how it could be electrical but not effect how the bike doesn't miss while it is running.I’ve posted this plenty of times. Here is a text book failing ACCT to compare but they sound different to me.
The bike in the second video is mine, and you’re spot on, that was recorded when the bike was sitting all day outside work and I just started it up. It would make the noise and it would fade in a few minutes but in a couple weeks time it started taking a lot longer to quiet down and that’s when I switched them out.They sound different to me as well. However the OP's engine sounds like it is running at a bit faster RPM than the 2nd example. The last one is the sound I recognize as it clearly is RPM related. The 1st engine sounds really fast and I also think it sounds a little electrical in nature. ( Like a set of contacts opening and closing real fast, but I do not understand how it could be electrical but not effect how the bike doesn't miss while it is running.
The odd rhythm has me a bit confused as none of the ACCT's I have replaced (4 total - 1 at a time) ever made a real rapid series of taps (or clicks) then stopped completely and then did it again. Rather, like the second video the chains rattled in time to the rest of the timing events, speeding up or slowing down, in the same rhythm of the engine's RPMs. After the motors were warmed up the ACCT noise was not as bad but it was still there. However when the engine was warmed up the ACCTs would only knock about half as long. Occasionally the knocking would actually stop intermittently, even while just idling if the engine was completely warmed up. When riding every day it often would not make any noise if starting and stopping frequently.
Great tip! And TikTok should be destroyed with fire. Just my 2 cents 😂Ominous - unfortunately nothing to add to the (technical) discussion here - but I saw the same thing with the Youtube "shorts" not being able to be embedded in this forum.
One way to get around it, find the URL for your short (using my video as an example)
h ttps://www.youtube.com/shorts/jlzjulAjmLk
Replace the text "shorts/" in the URL with "watch?v=".
This will render it as a regular YouTube video, and this resulting URL you can then copy/paste into our forum's text box.
Phew. Bit of a chore. But that'll get it to show up.
YouTube looks to be leaning really hard into the the whole "shorts" thing, probably to compete with TikTok for kids' attention.
Will do, thanks!Just to add my 2 cents, If you haven't already, I would change the oil/filter and check you have good oil pressure. It may be something with the hydraulic lash adjusters which require good oil pressure to operate. There is also an oil screen at the bottom of the case that can be checked for blockage in addition to the filter. Finally there is a little screen in the heads themselves that feeds the HLA's that may need to be cleaned. If it is cold out may try a different viscosity oil and of course, make sure it is good and warmed up.
Wow, that tapping did just shut completely off at 3 minutes. Has a similar rhythm and speed as Omi's.To jump in here, at risk of repeating what's been said, I vote for a failing ACCT.
I bought my 2005 with ~8000 on it and it started failing around 11k.
The consensus is around 17-25k, but I think when a bike is low mileage, they go early.
Below is my video. This was a cold start. At 3 minutes, it suddenly stopped but would return when I revved up.
It started making the noise on cold starts during a multi-day trip but it would go away when the bike warmed up.
Each day, it took longer to go away.
Try the Grumbo Trick to see if the noise goes away. That will tell you right away if it's the ACCT or not.
Excellent advice from you both, thank you! I've read and bookmarked the Grambo trick page for easy reference later.Wow, that tapping did just shut completely off at 3 minutes. Has a similar rhythm and speed as Omi's.
I think whatever it is, it not bad enough to worry about yet, but I would monitor it.
My acct taps lightly on cold start, but is gone after warmup, It's been like that for at least three years. It's not as bad as Jason's, but steady and louder than Omi's.
So thinking about Jason's noise, it came back after he blipped the throttle, I wonder if the acct plunger shaft gets sticky,. A chain or belt will tighten/loosen as the power changes. So his finally quiets down, then when he revs it the plunger gets pushed back by the chain. Certainly a weakness in the spring, but a sticky plunger explains it being able to recover and stop tapping again. The spring couldn't regain tension.
So many people have reported no help by installing new springs. They aren't going bad?
Oil gets through the acct, and so follows varnish. I didn't pay attention to the tapping after I ran Seafoam in the oil. I'll try to listen on the next start-up.
