1 - 19 of 19 Posts
Ok rebuilt the engine made sure all gears lined up with punch marks etc...
Put all the wires back on and in another thread mentioned having to buy a new starter relay. (Not sure now that was the problem)
The starter motor isn't turning over, read in another thread that the starter coil could be a problem. At one point I had a dumby light connected to ground and the starter motor and it lit up very dimly. Can't repeat that now -may be cause battery is very low. I could jump it with the car and try it again.
Not sure how to use the ohms meter to check this.
I am truely stumped. There is no motor turn over, cause the starter motor isn't turning the motor over. Any ideas?
Firstly, charge up your battery to be sure that is topped off and fully charged.
Make sure your wires are all clean and securely connected.
Try jumping the terminals on the starter relay with a large screwdriver to see if the starter motor will spin up, or possibly even take the positive wire from a set of jumper cables from the battery straight to the starter. If you have a full battery, and the starter is working, this will spin up the starter quite nicely.
Be sure the engine ground wire is on nice and tight.
Discussion Starter #4
double check neutral switch, clutch switch, ign switch, and run/stop switch
OK all ok except neutral switch is slightly loose on the nob on the bottom of the bike. But the neutral light comes on real strong, and it is in neutral I can roll the bike.
Will try jumping the starter tonight. Thanks
Well the battery won't charge completely so I guess I will need to get a new battery, this project will be on hold for a little while....
Discussion Starter #6
OK No new battery yet...but I read on here you could take your car battery, (Car not running) and hook to the starter, grounded to the bike to test the starter. Well when I did this with the key on it sparked. Now I had the battery positive unhooked but not the ground on the battery, hopefully that is not why it sparked. when I tried pushing in the start button it smoked and sparked...I checked the ground and the neutral switch. The stator wires are good and clean. I did relocate my r/r to the side and it is not grounded to the bike. Could that have caused the spark at the starter? I relocated it to the side cover which is some form of plastic. Help! I don't know why it sparked...
...unless his solenoid fried.....that could cause sparks, eh ?....actually....he should remove his right side cover, ground the (-), then tap the (+) on the solenoid ?...No ?...
I hate Jap and British electrics.......Jap are too complicated, and Brit are backwards....bring back the magneto and outlaw safety switches !!!!
Discussion Starter #9
OK wires were: Positive to positive on car neg to neg on car.
then had negative grounded to frame of bike and touched starter. The touch to starter sparked.
Then I tried hooking up the bike first. Ground to frame and positive on starter, then negative to car battery and just touched the positive on the car, that is when I got smoke from frame and starter.
The "solenoid fried" what solenoid? To my understanding that is the thing the spark plugs are hooked to and there are two of them? (One in front of the bike and one in back of the bike) Or were you talking about the starter?
In all my reading I hadn't read anyone getting sparks from touching these items? was the starter suppose to be unhooked? Cause I didn't take the wire off the starter that goes to the bike. Just hooked up cables.
Letting smoke out is a bad sign.You probably just caused yourself some new problems. The solenoid he spoke of is the starter relay.,your positive cable on the battery should go to one side and the other side of id goes to the starter itself.
If you want to test the starter with a car battery isolate it by removing the starter cable at the starter. clamp the ground on the starter body and then touch the positive jumper lead to the bolt you just took off the starter.if it sparks ,it is normal for it to spark a little but if you hold it on there for a second it should crank the engine over,if not .The starter is bad or it is bound up,or the engine is seized up some way.
If you had the bike's ignition ON when doing this...you probably caused some other issues by feeding the car battery voltage backwards throught the wire harness. Ignition off, battery disconnected.....touch car battery leads to the frame and starter positive.....this would turn the starter but the bike won't run since no other systems on the bike are powered.
The solenoid they are talking about is the starter relay located under the left side cover that is activated when you hit the start button.
What you should have done was just simply attached the car battery to the bike battery leads (bike battery unhooked) and started the bike normally.
Discussion Starter #13
Ok the starter relay was just replaced so know its good. Will hook up jumpers again tonight not sure where u can ground the starter with the neutral the bolts that hold that round thing to the front bottom of the bike are pretty small and my cable clamps are pretty big!
You can put the ground cable anywhere on the bike frame that makes good contact, assuming the starter is still bolted to the engine. I was testing last night with a ground clipped onto the front brake rotor.
I've found that new parts aren't always good. Have to keep that in mind with any troubleshooting, whether bike, car, etc.
I would not ground though a bearing.
Think I see what you're getting at, but I wasn't pulling amps, just testing for 12v with the DVOM. But I'd think there would be enough contact in the area to prevent arcing through a ball bearing.
Yeah, BeeSea, don't ground on a wheel or axle, but the frame, engine, kickstand etc should all be good. Right on the starter case itself wouldn't hurt if it will clip on there.
Discussion Starter #18
thanks will try and report back if there is any difference.
I really appreciate all the good ideas and cautions! I need them!
thanks again.
Discussion Starter #19
If you want to test the starter with a car battery isolate it by removing the starter cable at the starter. clamp the ground on the starter body and then touch the positive jumper lead to the bolt you just took off the starter.if it sparks ,it is normal for it to spark a little but if you hold it on there for a second it should crank the engine over,if not.The starter is bad or it is bound up,or the engine is seized up some way.
OK well tried that it did spark and then nothing...so guess I will be pulling the starter out, before we do that my husband wants me to try popping the clutch, he thinks that might jar something loose like tapping on the starter. As long as he's pushing it back into the garage I don't care! hahaha
1 - 19 of 19 Posts
