1 - 3 of 3 Posts
Greetings to one'n'all
On the advice from a couple of the other members, I'm about to take the ignition switch apart. Does anyone have a diagram or photo of the inside to show what the springs etc should look like?
I took apart the controller off of a washing machine once and since then have a physical aversion to springs & balls in switches!!!
Or is it so simple that even a numpty can do it?
Martin here is a link to Crobins photos of a teardown she did a year or so ago, of the cylinder lock and ignition switch.
http://www.vn750.com/forum/showthread.php?t=8998
There is a link in there to Diannas text description of getting inside the electrical switch to check wiring soldered to contacts, and cleaning contacts, etc.
There is also a link to global reckons 4 photos of the dismantled electrical switch, soldering, wires, dielectrical grease usage, etc.
I hope this helps.
Hi Gordon,
Thanks for that. I shall study prior to stripping it down
1 - 3 of 3 Posts
