21 - 32 of 32 Posts
Discussion Starter #21
To an extent, all engines will have an increase in idle rpm with an advance in timing, but that won't be an indicator of correct tune.
I have been reading up on ignition timing quite a bit. I'm no expert, so here's my understanding. Please correct me if I'm wrong, because I want to do it right!
From what I understand, the best timing at any given RPM (assuming no knock) is the one that gives the most torque. I saw a video that gave a rough graph of torque vs timing. When well retarded from optimal, the graph is pretty steep and each degree adds a lot of torque. As you approach optimal, the graph levels off and then starts to drop when you pass optimal.
I'm not on a dyno yet, so "highest torque" at idle is highest RPM for a given idle setting. Same tuning process as setting idle mixture. One could also say, highest vacuum at a given idle RPM.
It will be next to impossible to tune partial and full throttle openings below 2-2.5k without lugging the engine, so I'm planning to revert to stock timing once the throttle cracked, up until 2-2.5k. Hopefully it won't make the throttle response weird.
Your last paragraph is a good plan, since less advance is needed at low rpm and then should follow an upward curve increasing with rpm.
I keep forgetting you have adjustability over the entire rpm range. Unlike mechanical systems that are somewhat a compromise between best and worst.
Discussion Starter #23 (Edited)
I'm still learning more about timing, and hoping to share what I've found both from research and experience.
According to this page:
“If the spark occurs too soon, the engine will fight against the pressure in the cylinder creating extra heat and possibly cause a pinging problem that may do engine damage. If the spark occurs too late, the maximum cylinder pressure will occur too late, thus not converting the fuel energy into power, but wasting it as heat that the cooling system must get rid of.”
It sounds like my advance to 8 degrees at idle with no throttle will reduce the engine heating at idle. Additionally adding some advance at cruise and partial throttle acceleration should also reduce heating. I have also considered retarding the timing during a cold start to try to warm up the engine faster. Apparently some OEMs do it with cars, though their main goal is heating up the catalytic converter. I don't have a temperature input to the controller, but I could look at the vacuum / RPMs associated with cold start on choke. I don't have the cold start data log in front of me right now, but I would expect high vacuum and an RPM 2000-2500, as that's where my bike idles with choke.
This controller is almost infinitely adjustable! On the left column, I can select 10 different vacuum pressures (105 kPa = no vacuum = 0 inHg, 0 kPa = full vacuum = 30 inHg), and 15 different RPMs for a total of 150 different points of adjustments in timing! It will interpolate between them. Not only that, but I can choose what the 15 different RPM points are and what the 10 different vacuum points are. Right now, my RPM points are every 600, but I could set each column to whatever I wanted. I have two individual tables to work with as well, so I set up a 2nd table with only three columns (5 @ 1100, 25 @ 3500 and 25 @ 8500) for stock timing. I'll be able to switch over on the fly (even while riding) at the flick of a switch, to be able to compare to stock timing whenever I want.
I've had the wrong springs on mechanical advance and the engine would just start bucking when you tried to step on the gas. The advance curve was too steep.
On the dirt cars we were stuck with either a locked down advance or playing with springs and initial settings. Using a locked advance meant using a special procedure for hot starts, or getting a push truck.
It's really trick to have full control over the spark curve. Will be interesting to see dyno results.
Discussion Starter #25 (Edited)
I uploaded the wrong log files in post #19.
Here are three log files that I made on Saturday.
Proper file extension is .xlsx or .csv depending on the name.
The .csv file has the raw data and no graph.
I graphed the RPM, the carb vacuum, the ideal ignition timing (stock 1100 RPM and lower = 5 degrees, 3500 RPM and higher = 25 degrees), and what I think is the actual reported ignition timing.
The timing data, I calculated as:
Timing = 36 - (DATA / 2.56)
This formula doesn't really make much sense, but the graph using that formula lines up pretty close to the ideal timing numbers.
52925
On the other hand, this same column of data I had previously calculated as dwell time (before my goofy calculation above).
That would make more sense, as this section of data had an idle advance of 8 degrees, and a decel advance of -5.
I'm still decoding this data....sigh
Discussion Starter #26 (Edited)
I found the reported advance!
Data bytes 105 and 106 are the advance for each cylinder.
Blue is hand calculated advance (based on the reported RPM), and Yellow/Gray are the reported advance values from the controller.
It only reports back integers, but it otherwise perfectly follows what I expect to see.
52938
I assume 105 is cylinder 1 and 106 is cylinder 2, but it really doesn't matter since I'm running the same timing on both.
I updated the logging program file in post #16 to version 1.3, so that it now logs the actual advance used.
I have a bet going regarding how ignition timing affects engine heat at idle. I say more advance, coupled with less throttle to get the same RPM, will result in lower engine temperatures. My coworker say advancing the timing will add heat. Since I'm able, I'm going to run 1100 RPM with both at stock (5 deg) timing and compare cylinder and exhaust temperatures. Then I'm going to run one at 7 and one at 4 and compare cylinder and exhaust temperatures, then swap them and compare cylinder and exhaust temperatures again. Loser has to buy the winner lunch!
I think that more advance with less throttle so that the power output is the same, results in less heat in the engine and exhaust. I think he's thinking that more advance with the same throttle means more power, so more heat.
I mean, what else am I going to do while I'm waiting for spring?!?! I'm at least going to wait until the temperature is > 20F!!! We're supposed to hit -25F this Sunday.
Discussion Starter #27
I collected more data today.
This was just a smooth run up in RPM, with attempts to hold at my test RPMs.
3000,3500,4100,4800,5500,6200,6600,7000,7500,8000 and 8500.
These RPMs correspond with 40,50,60,70,80,90 MPH, then 6600,7000,7500,8000,8500 fill out the rest.
52986
The red is the RPM and the gray is the vacuum inside the carbs.
The X axis is time in seconds.
Higher is less vacuum, with 0 being a perfect vacuum and 100 being no vacuum.
Ignore between 1100 and 3000 RPM. I was experimenting with retarding the timing in that range.
I noticed that from 3000 RPM to 4000 RPM, there is a lot of vacuum in the carbs. IE it doesn't take much throttle opening to hold those RPMs.
At 3000, 3500 and 4100, I measured 66.9, 69.7 and 68.2 respectively.
Above 4100, the amount of vacuum decreases like a straight line until ~5300, where the average remains fairly constant until redline.
Know what happens above 4100? The ignition is no longer advancing, so I see room for improvement at part-throttle operation!
52987
Stock timing stops advancing above 3500 RPM. Mine is supposed to, but it was set to follow stock, except at vacuum readings below 67, and I had some dips to 65.
I plan to bump the timing at each of my test spots and see if I can hold each RPM with more vacuum (lower number). That would indicate more efficiency. I'll hold WOT timing at stock until I can carefully test it on a dyno.
Now, the reason for the weird timing below 3000 RPM. I was hoping to find the operating point for when the bike was running on choke and retard the timing. This would bring down the RPMs while on choke, and IN THEORY, add more heat to the engine to speed up engine warm up.
In practice, adding choke puts it in the 2000 RPM and 85 kPa range. This is the same range that you pass through as you blip the throttle to come off idle. The end result was TERRIBLE off-idle response. You can see in the graph, the engine struggles to rise above 2000 RPM as I gradually added throttle, then shoots up to 3000 RPM where I had to remove throttle to hold 3000 RPM. It would be un-ridable!
Interesting data. Can't wait to see a dyno run. There's one close to me, they run all night sometimes.
On the last graph, what is Advance 1 and Advance 2? Two profiles in the new ign box or is one of those stock?
Seems like a hard pull in neutral. :oops: 50 seconds at the upper rpm? Am I reading it right?
Discussion Starter #29 (Edited)
The graph is RPM (blue) vs carb vacuum (gray). I did a slow ramp up of RPM (ie just enough throttle to increase the RPM) to get a baseline for vacuum readings with stock timing. So it's not 50 seconds at high RPM.
Advance 1 and Advance 2 are the individual cylinders. The controller allows you to set one cylinder different from the other. Not an entire timing map per cylinder, just a possibility of setting one cylinder 1 or more degrees ahead or behind the other. The data coming back doesn't show less than whole degrees, so if the actual timing is right at a half way point, one might round down while the other rounds up. Otherwise, they match each other.
I did a few more of those today, bumping the timing up each time. I found I was able to give it 2-4 degrees advance with a noticeable increase in vacuum. I think at higher RPMs, there is a resonant effect, causing the sparatic readings.
I also logged a couple rides, including a WOT pull in 3rd from 2k to redline, and a closed throttle deceleration back down to 2k. I don't have the data with me at the moment, but it looks like there is a slight restriction at the top end at WOT. It starts to pull a vacuum even at WOT. This suggests an ear shave might help top end HP.
I tuned the idle timing at 7, with timing of 8 at 900 and 1 at 1300. It's a trick I learned to stabilize the idle. As idle drops, the timing advances pushing idle back up. As idle rises, the timing retards, pulling idle back down. It's really cool, on warm start it pops up to about 1500 and drops right back down to 1100 on the nose. Same with coming off throttle. RPMs drop like a rock and stop at 1100 like it's a brick wall! Cracking the throttle puts it at a different vacuum level, so it bypasses the retarded timing at 1300. This also prevents the need to adjust the idle as the bike warms up.
Speaking of walls, the rev limiter is a nice feature! I missed a shift and hit neutral instead. This time however, the engine didn't wind out to 13k but held right at 8700.
Lastly, at high vacuum (deceleration), I pulled the timing to -5 degrees for a late burn. It's a nice predictable double pop coming off the throttle, with more pops as you slow down. To each their own.
Discussion Starter #30
Here's part of my ride yesterday. I'm blipping the throttle at idle, then accelerate to a 60 mhp cruise, with a brief 4th gear acceleration before slowing down for a red light.
52991
And here's a WOT run in 3rd gear. Notice the droop in the red as RPM goes above 7k?
52992
This is my current timing map. Throttle is the Y axis. It idles around 68 kPa. Decel is below 50 kPa. WOT is ~99 kPa at my elevation. At 97+ kPa, I'm running stock timing
52993
Discussion Starter #31
I added a switch to toggle between stock timing and my custom timing.
I did make a change to "stock" timing where it runs 7 degrees at 1100-1300.
True stock is 5 at 1100 and 7 at 1300. I did this so I don't lose 2 degrees of timing at idle if I switch back to stock.
Here's the idle recovery with "stock" timing (left) and my timing (right).
Notice with the "stock" timing, the RPM slowly settles in after reaching 1500.
With my timing, it drops straight to 1200 before settling in.
The green is the actual timing, and I'm using it to regulate the idle.
53015
I also added a shift light that starts blinking at 8000 (blink rate increasing with RPM) and it's full on at 8500.
It's zip-tied to my clutch cable.
It's more of a novelty at least during day time. It's not quite bright enough.
Here's a video demo of the idle recovery, rev limit, and shift light.
Switch up is "stock" timing, down is my timing.
You can also hear the decel pops as I back off the throttle.
I rode through a city street with brick buildings on both sides.....and WOW it's loud!
Another reason I'm glad I added the "stock" timing switch. I can turn off the pops whenever I want.
Lastly, my tach is slightly inaccurate.
1100 RPM shows up just under the "1" mark on my tach, and 8500 shows up almost at the "9" mark.
Notice too, when the rev limiter kicks in, the tach goes crazy.
The final step is do some typical riding and compare MPGs with new and old timing. I'm running 1-2 degrees over stock at cruise, so it should have an effect.
Hey, I know how to make it go off like a howitzer if you're interested. :) It's only single shot though.
Waiting to see ride results, will be interesting.
21 - 32 of 32 Posts
