The idle speed screw is attached to a spring coils. That one turned. It turns a screw on a bracket. If you can reach behind the knob, you may be able to turn the coil springs by hand, or with the pliers. Take a look and see if you see any movement of the spring when you turn the knob clockwise should increase the speed I believe it could also be out of adjustment and may require a number of turns to take up any slack study it closely. It’s really a simple device and they are simple cures for it.
