Let me start with, hello from Massachusetts. First time owning a Vulcan, and seriously working on a motorcycle. I've been a backyard mechanic all of my adult life, but this bike is a little over my head right now. I didn't know what i was getting myself into.
so lets start with what i bought. an 02 vn750, that apparently the previous owner bought from a shop that did custom work...great. what i have in front of me is a bike where all the electrical, mounting locations, battery cage, has all been removed from stock location, above the goats belly. its just a spaghetti of wires. The R/R, reserve light unit, blinker relay, a Mitsubishi igniter box, and the junction box are all just hanging in the space there the battery is.
Yesterday (the day i bought it), when i first hooked a battery to it, i got absolutely nothing. I got power to the white wire at the key, and 2v coming out from the yellow, etc. at this point the blinkers started working, but after cycling the key a few times, they stopped working. Next, i pulled the key switch apart, cleaned and reassembled, and stopped for the night.
Today, i bought a new AGM battery and when i hook a battery to the bike, and turn the key on, I now get power at the key, and full 12v out to the ignition, and other wires. One problem seemingly solved.
Now, I don't know where to go. probing around with a multimeter, i have 12v power going into the right hand controls with the srop switch in run, and when off, switches to 11.xx volts. nothing changes when i hit the starter button. this is my big issue, no matter what i do, nothing will kick on the starter besides just jumping the starter solenoid. no matter if its in neutral, kick stand up or down, clutch in or not. the plug to thge clutch lever seems fine. i have not found any obvious broken wires yet. im thinking tomorrow im going to have to bite the bullet and unwrap the wiring harness.
I've seen these bikes are plagued with electrical problems, and I'm wondering if i should just cut the crap and rewire the bike, with the solutions found on this forum now, instead of trying to piecemeal everything. am i missing something painfully obvious? can someone point me in the direction of a step by step of how the ignition, starter system works?
Edit: here's a link to an album I'll be uploading any pictures to. Tell what you think or if there's any specific pictures toud like to see.
