1 - 5 of 5 Posts
Discussion Starter · #1 ·
Got broken in storage. Right front. Wiring ok. Light hangs down. Looking for a simple fix that looks good? Ideas?
You can run a search on the forum but I’ve read a few posts where folks have used and short tube inside the stem like a cut ballpoint pen. Just needs to be sturdy the you can glue the crack in the stem. This is all assuming the black part is the broken part you’re talking about.
This is a common problem with many bikes. I use lamp repair thread from a hardware store. Cheap, easy, and it works.
53288
Bic pen and black electrical tape
Sent from my A501DL using Tapatalk
If it was rear I have a couple that I removed from my bike and don't need anymore.
1 - 5 of 5 Posts
