1 - 9 of 9 Posts
Gang, what tool do you use to open the side cover. I couln't find anything in my tool box that would do it. I had a 5/8 flat tip that almost stripped the head of the bolt, so I backed off.
Also for some reason the spark plug socket I have in the tool box wasn't able to fit over our plug... go figure..
Growling at the World...
I have a real big screw driver that I use. Some here use their key edge, but I've only had to do that on the road to replace a fuse.
I use the edge of my key, but have gotten pretty frustrated with those bolts and started to replace them with allen bolts. Not as pretty, but definitely more functional.
85 VN 700
Mine are held in with either galvanized or stainless deck screws and washers... not pretty but functional - PO did it and I haven't bothered to replace em with something better.
Key is no go... the bolt is either torqued too tight or has rusted out..
Will stop by Pepboys on my way home and see if they have a large flathead to get the job done.
85 VN 700
They overcharged ya...
However I didn't see where ya saw MSRP - went to ron ayers and they're asking 6.77 plus shipping http://www.ronayers.com/browseparts.cfm?searchstring=92110-1111
found under
http://www.ronayers.com/fiche/400_0438/owners_tools/owners_tools.cfm?man=ka&groupid=10770&parent=10700
I have an old 1 1/2 inch wide wood chisel I use works like a charm. If its stuck use vise grips on the shaft for extra leverage.
As for the spark plug socket I went and purchaced the actual spark plug socket for 35 bucks. What a rip the kawasaki site says msrp 3.50 for
Item# K56019-27282
:mad:Im going to have to have words with the shop that sold it to me. :mad:
http://www.kawasaki.com/DefaultFrame.aspx?strContentUrl=/SITE/VIVEHICLEINFORMATION/VICHOOSEVEHICLE.ASP
Hit it with PB Blaster before you start torquing away at it - might come off a little more easily. :)
Discussion Starter #9
Got the bolts opened up with a 2 feet long flat head screwdriver... While putting them back on I just used the key to tighten.. So next time I should be able to get to them easily.
While has the side cover out..I also took the battery out and unhooked the battery case to see how much clearance I had to get to the R/R...biy that is tight.
Anyway does anyone know what is the round black thingy bolted on to the battery case towards the front of the bike.. I think once that is removed it would be easy to get to the R/R.
1 - 9 of 9 Posts
