1 - 12 of 12 Posts
Vulcan Bobber
Somebody done this test before? just I wanna make sure mine is working Ok, I wanna try like the manual say but Is it truth I can use only kawasaki hand tester?:doh:
Vulcan Bobber
No revvire but I get some electric problems....tachometer is not working, the inside lights are fine but I think the black wire from IC ignitor is who send signal to the tach and is not doing that, also my bike sounds on the road like if sometimes rear or front cylinder is off (not sparking I guess) so that's the reason I would like test te IC Ignitor, please if some vulcanator :)rockon:) know how do it.......:itchy-scr....... let me know.:huddle:
The ignitor either works or it doesn't. If you have an intermittent problem, it's usually a wire or connector.
Sky Rider - It works or it doesn't right? So if running at higher RPM (4000) and the rear cyl finally begins to fire then its likley not the Ignitor? What else would cause that. Ignition Coil maybe? I can start the bike cold and run at idle for ever and the rear cyl will never fire. I can place my hand on the exaust and its not even warm. Front is as hot as can be. Rev the bike up to around 4000rpm and the rear cyl kicks in and it revs up to around 6000rmp. I can't pinpoint the problem. HELP!
Aminjuez - Sorry man, not trying to hijack your thread, but we seem to be having the same question. I was just reading in the manual about having to have the Kawasaki multimeter to test the Ignitor myself. Trying to trouble shoot this rear cyl problem. Hope we both can come up with a solution! Thanks.
my rear cylinder has done this a couple times but ive had electrical problems and carb problems so i would look to make sure the plug wires arent arcing off the jug.... start ur bike in the dark and look for sparking around the plug, if it does it then get some wires or wrap some electrical tape on em. could also be the coils. i doubt its the ignitor
Hi All
Just got back to KL after a work trip around the world and went to start the bikes, so I can give them both a run and blow the cobwebs off.
The VFR750 starts first time no problems at all, just as always.
The VN750, will not start, keep cranking, still will not start. have petrol smell from the exhaust so fuel seems ok. Took out a plug, a bit damp from fuel tried to start, no spark. Tried to start again, biggest backfire I have heard in a long time, sounded life a rifle going off, woke up the neighbours nicely.
Just had new coils fitted to try and improve the hot starting, checked the coils, all ok. Thought I'd better check the ignitor, after the fight to get the bottom bolt out and to find the Fluke meter I get around to the test. A good number of the results are totally out of spec. Tested the ignition coils and the pulse coils and they are all within spec.
Got to suspect the ignitor, now try to get a replacement, my local shop - $420.00 new, bit over the top so hunt Ebay a find a secondhand one for $40 + postage. Waiting for it to arrive, and hopefully it fixes the problem. I'll let you all know when it gets here.
I have attached a spreadsheet (in a zip file as I could not attach the Excel spreadsheet) I put together to make the recording of the Ignitor tests easy, it also has my test results as well for reference.
Now it gives me a chance to clean the VN750 while it is all apart. More work, and the VFR sits there saying ride me, ride me which is very tempting.
Have a good weekend.
Regards
DaveT
Kuala Lumpur
I'm having the exact same problem. Rear cylinder doesn;t fire at idle and kicks in just fine around 3000 RPM. Looking at coastering and adjusting the air/fuel mixture screws. Not sure it will help with the spark problem.
Anyone?
:doh:
On mine, the high speed jet in the rear carb vibrated loose and fell into the bowl. The bike idled fine but the rear cylinder would cut out at 3k or so and it struggled to get up to 50 mph. When I disassembled the carb and found the jet, I screwed it back in and made sure it was nice and tight, put the carbs back in and have had no problems carbureator wise since.
Aminjuez, the easiest way to test the ignitor is to simply pull a spark plug, ground it and hit the starter momentarily and see if there is spark. If the plug sparks, the ignitor is working. If no spark, back track from the plug to see if there is a broken wire or other malfunction in the electrical system before deciding it's the ignitor. The tach not working can be from several problems as I understand it. The pick up coils also feed the tach and I believe even the side stand switch can affect the tach as well.
Mad Max, you may have the opposite problem from me. Your idle jet may be clogged but the high speed is open. Try the Seafoam trick first to see if that clears the carbs but if not, you'll have to pull them and clean them. I haven't had much luck with Seafoam but others here have.
Thanks for the advice, Skyrider. the Seafoam is not getting it done for me. Can I take out the fuel/air mixture screws and blow then out with canned air without taking the carbs all the way off? These are the slow jets, right?
I'm at such a loss as to what's going on. It's almost like there isn't enough compression in the rear cylinder but I checked the compression and I'm getting 125-135 in the rear and a pretty solid 150 in the front. That's within specs, I believe.
( I think I'm going to switch this post to the engine and exhaust section.)
:blah:
Kawika
Anyone?
:doh:
mad_max: what did you eventually find the problem to be?
1 - 12 of 12 Posts
