VN750 Spec Sheet
I don't know about the VN700, but here are the VN750 specs. The VN700 should be very close if not idential to most of these.
Horsepower @ RPM
65 @ 7500 per Mama Kaw
52 per an individual test
Torque ft-lbs @ RPM
47.7 @ 6500
1/4 mile seconds @ MPH
13.70 @ 97.6
0 to 60 in seconds - we don't know at this time
Top Speed in MPH - we don't know for sure
NOTE: Additional performance info provided by FARRIS on 5/28/04:
[A] = 1/4 MILE, SECONDS / MPH. = 0-60 MPH, SEC. [C] = 40-60 / 60-80
RUN-ON, SEC.
[D] = 200 YARD TOP GEAR ACCELERATION FROM 50, TERMINAL MPH.
'VULCAN VN750', 750, '86 TO NOW [A] 12.91 / 102.7 4.40 [C] 4.50 / 5.10
[D] 72.7
SOURCES FOR ABOVE : 'CYCLE' [ MARCH, 1986 ], AND 'CYCLE WORLD' [ AUGUST,
1988 ], MAGAZINES.
ENGINE 749cc, Liquid cooled, 4-stroke, V-twin, 8-valves, DOHC, rubber mounted
DISPLACEMENT 749cc
BORE X STROKE 84.9 x 66.2mm
COMPRESSION RATIO 10.3:1
FUEL CAPACITY 3.6 gal.
FINAL DRIVE Shaft
CARBURETION Keihin CVK34 x 2
IGNITION Electronic
TRANSMISSION 5-Speed
FRAME Double cradle, high tensile steel
RAKE/TRAIL: 32 degrees/5.0 in.
LENGTH 90.4"
WIDTH 33.5"
HEIGHT 48.2"
WHEELBASE 62.2"
GROUND CLEARANCE 5.9"
SEAT HEIGHT 28.9"
DRY WEIGHT 483 lbs.
BRAKES / WHEELS / TIRES
SUSPENSION Front: Hydraulic telescopic fork 5.9 in. travel
Rear: Air assisted dual shocks with, 4-way rebound damping 3.5 in. travel
BRAKES Front: Dual Discs
Rear: Mechanical Drum
TIRES Front: 100/90-19
Rear: 150/90-15
