1 - 7 of 7 Posts
I'm new and learning how to post pics. I removed the factory bolts holding the grab rail. Next I tapped the holes to ASE 5/16 to accept longer standard thread bolts. I then cut some spacers to offset the brackets. I used a metal brake to bend a rest place for the bags to sit on. I bolted the bag to the bracket with a 5/16 X 1 inch bolt. I used 5/16 x 3 1/2 inch bolts to fasten the bracket to the grab rail factory holes. I put a 3x3 inch plate with a 5/16 hole in the center inside the bag to serve as a washer with a large surface area. It was a design on the go, a lot of trial and error. I could have just bought some brackets but the ones I saw didn't look right. See the rest of the pics in the gallery. Let me kno what you think.
You'll have to look at the gallery in his profile. Not bad looking and sure looks sturdy!
Heavy duty!!I guess you won't be worried about sagging:smiley_th
1 - 7 of 7 Posts
