41 - 49 of 49 Posts
I don't think it had the time to circulate. it was on for 2-3 minutes before I shut it off to ask you guys. I'll have time to run it tomorrow and check the temps. hopefully it'll get better
Ok, could still be some air in the cooling system. That might account for one cylinder getting hot so quickly.
I wouldn't pull the carbs until we know what's going on, if it's running on both cylinders now, the carbs may be ok.
2006 Vulcan 750
Discussion Starter · #42 ·
Forgive me if this is a stupid question. But how do you know if a cylinder is actually running?
Sent from my Pixel 6 using Tapatalk
Usually by the temperature of each pipe at the head. The exhaust mixes in the goat's belly, so checking at the tailpipe isn't very accurate.
Once you're used to the bike and how it runs, you'll know by the 50% loss in power and idle speed.
2006 Vulcan 750
Discussion Starter · #44 ·
Wow! So even if I Lose a whole cylinder the bike will still run, V twins are amazing.
I'll do some experimentation and get back to you on this
I forgot the easy test, pull the plug wires from one cylinder.
2006 Vulcan 750
Discussion Starter · #47 ·
Merry Christmas, and a happy new year. finally got to do some testing, both cylinders work. bike runs beautifully without any problems. ran it for 2 hours and the weird white smoke went away on its own.
I'm getting a reading of 400 degrees directly where the exhaust pipe connects to the engine. is that normal or too hot?
Honestly don't know what it should read, but I'd say that's about right since it's firing correctly.
The white smoke was probably just water vapor. If you live in an area that has winter, you'll see that a lot on almost any vehicle.
2006 Vulcan 750
Discussion Starter · #49 ·
Well I guess I have a fully working bike now. time to do some learning.
I really can't thank you enough guys. couldn't have done it without you!
41 - 49 of 49 Posts
