1 - 5 of 5 Posts
Dear friends,: I have a Kawasaki Vulcan VN750 1995. I had to replace the stator and voltage regulator but the bike worked very well. After replacing the parts the bike does not work anymore. Only works if you keep the start button pressed. Anyone know how to solve this problem? to help with information, is replacing CDI box and fuses. To no avail. I appreciate the help.
:BLAM::BLAM::BLAM::BLAM::BLAM:
Someone posted with the exact same problem about a month ago. Don't think we heard if it got fixed or not. Shouldn't be too far back to find.
The problem was, it would only run if the starter button was held in.
Edit: Here it is, was back around page 3. No resolution posted, but you might get some ideas of things to check.
http://www.vn750.com/forum/showthread.php?t=23729
Do you have good voltage at the coils? Measure it, it should be 12V.
Where are you from? Your name seems either Mexican or Spanish. I'm Mexican myself.
1 - 5 of 5 Posts
