Help, oils drain plug broke off
123 Views 5 Replies 4 Participants Last post by  Spockster
Went to change oil today and the head on the plug was already completely rounded off. I couldn’t find an extraction socket at the store so I used a rotary tool to make a slot the. Used a flathead impact screwdriver to try and bust it loose only I ended up breaking half the head off. Any tips on getting this out? 1986 Vulcan 750
Automotive tire Rim Automotive exterior Auto part Automotive wheel system
See less See more
1 - 6 of 6 Posts
You could slot the plate on both sides of the missing nut, then use a chisel and go in it at a 45° angle and start walking it around. Once it starts to move you should be OK you’ll need to buy a new piece because that bolt head is part of the whole plate, apparently it was tighten down too much. There’s an O-ring underneath a jthat plate. It just needs to be snug you don’t need the bull it
  • Like
Reactions: 1
I'd just use the chisel and bump the cap counterclockwise.
eBay should have the cap.
  • Like
Reactions: 1
Notching the plate and the chisel worked thank you!
  • Like
  • Helpful
Reactions: 2
When you put the new plug on, I believe it has a rubber seal on one side. Some folks will rub a little oil on on drain caps to prevent it from sticking in the future. I've always done this with cars. Should be okay to do on a bike as well.
  • Like
Reactions: 1
Just don't overtighten it, just snug is enough.
  • Like
Reactions: 2
1 - 6 of 6 Posts
