I'm not exactly sure about your readings regarding ohms however, the voltage seems qute good and what I would expect from that stator. It sounds as though you did well finding out a short in the stator. I must confess the only access I have to my stator is the small opening above the "pickup coil points" and the bit of the grommet where the output leads feed the R/R. Were my stator or the stator (also Electrosport, but older) installed in my son's bike to short out there would be little I could do. Without pulling the stator as I have not done the tuxedo mod either.
His first stator (original) and the Rick's stator that replaced it were both showing as shorted out to the engine case. When they were pulled, although there was some discoloration in one place the coating on the windings looks to be intact. Regardless each of the 3 output leads on both shows a short and the stators needed replaced.
Can't help regarding the horn. The only time I find out if mine is working is when I push the button by accident. About once a week.
