1 - 6 of 6 Posts
It may be normal, but the bottom third of my headlight looks like its not working.
I have no idea how old the bulb is and wouldn't mind going to something better if indeed that is my problem.
If a new bulb is needed, suggestions of what to get would be appreciated.
Jon
Hi, Jon -
The "lower third" sounds odd, but may be a burned out filament (not surprising, really, if it's the bulb that came with the bike). I've got the Sylvania Silverstar- pricey, but it pulls a lower wattage and lights up the road much better than the old "regular" bulbs. Check the Verses under I think Lighting/Headlights. There's some discussion in there about the comparison.
85 VN 700
Another reccomendation for the silverstars. You'll need a H4, will set ya back around $20. I installed a silverstar on my bike and WOW what a difference.
Curtis
Hmm, does it look like that with high beam and low beam?
Low beam lights the upper portion of the light (the reflection makes it shine downward) and high beam uses the lower portion (reflects up)
Tim that may be the answer. It seems like other bikes light up the whole lens, I guess ours just doesn't.
Probably go get the H4 anyway, bulb could be factory??
Thanks,
Jon
Avid Rider
Get the PIAA ultrawhite plus H4 bulb, it will run about double the normal bulb, but also give you double the light (at the same wattage draw). I loved mine.
1 - 6 of 6 Posts
