1 - 20 of 29 Posts
"ya can't live forever"
Hey y'all I did the goat belly this Saturday !!
Easy as could be and man does it sound great "just like a cruiser should !!"
It took about 4 hours but could have been less if not for a very rusty bolt.
I have a little popping on deceleration but ya know I kinda like it.
I did not feel any difference in low end but much more power in the high band
just like some one previously said "it was like flying".
I was able to use a standard u-clamp on the right side by rotating the shield
a few degrees upward.Well thats the story.Another mod accomplished.:pepper:
Uber Member
did you use scooter works degoat kit, or you make your own?
Gb
I used my own method but I did take the advice of one of the guys who is a member here. Total cost in parts was $ 19.09 including tax. All you need are two lengths of 1 3/4 flex pipe,two u-clamps keep the old strap clamps and a hacksaw.
If you Google "goat Belly'" you'll come across the detailed instructions that I used.
Uber Member
thanks for the info, i think i may do that untill i can find someone to make some custom pipes for me
Say there Artman,
That is a really good idea. But don't the flex pipes leak a bit of sound and impact the quality of the tone? Many years ago I used them on a '64 Chevy Impala Doug's header installation because the X frame design forced a bend and exit toward the outside of the body which required a rather radical bend in the pipes that linked the headers to the mufflers. Sorta heard a hissing sound. That link required a sharp and peculiar bend to get back to the mufflers. Later had custom pipes made because of the sound that sorta "leaked" through the flex pipe. Perhaps you do not have a similar sound because the egress is rather straight, by comparison.
The Scootworks solution is good if you spend the time to make for a good leak proof tight fit.
Bye,
Sam612
Discussion Starter #6 (Edited)
Sam you are correct ....... there really aren't any extreme bends to be made
and I probably should have mentioned that you must install the flex pipe in it's compressed form and not fully extended. So basically I have no leaks and the tone is great !!
Well I took mine out today. Two lengths of 1 3/4 flex pipe,two u-clamps .. Pretty Easy but I guess I was in too much of a hurry to take it out with the new sound. Have two minor leaks but am fixing those tonight. I also saw no real difference on the low end and more power at the high
Today must have been goat belly day, took mine out also. Had Cobras and uncontrollable popping so I bought a stock system from Crystalship and ran that with viturally no popping(I had backed out the mixture screws) will tinker with it somemore as I don't really care for the popping .It does have less grunt off the line but more power over 4 grand. Will see how my neighbor likes it at 5:30am.
HAWK
I used the Scoot works kit, I would not go back.
It comes with heatsheld tape. It also had plugs to get rid of the reedvalves(Marble). I would recomend putting zipties to hold them on. I lost one because I didn't.
I did have to adjust the air screws, it is in the verses on how if you don't know. I also drilled out the screens in the mufler. If you look in the motorside of the muffler you will see what I am talkng about. it gave free flow through the muffler. I have ridden with people with V&H pipes and sounds very close.
Good luck
How labor intensive is this to do ? Do you remember how long it took you? I know nothing about reed valves. Can it be done without messing with reed valves? Thanks!
__________________
--bye , bilyum--
Should be less than a hour if your exhaust is in good shape, a little longer if your hardware is rusted.
I completed degoating and also adjusting carburetors . Will try it out tomorrow. I notice my left side is a little louder than right side. I guess its because left exhaust pipe is shorter. I think it should make the life expectancy of stator much longer. Also added a battery voltage monitor , which i really like. Just knowing what is going on is nice. You guys have saved me a bundle of money and are in the process of making me a pretty good wrench.Your posts and threads take you right to the point and save a lot of research. Thanks
Mine was degoated by the previous owner, with (I believe) Cobra pipes added on, and the right side seems to sound louder to me, when I'm sitting on it.
If I get behind the bike, they sound pretty much the same.
how does de goating and coastering affect gas milage? would like to know before i take on this endeavor. thanks in advance for any info on this subject you can share. john
What The !!!!!!!!
Please excuse my stupidity I am new here and a new Vn 750 owner But what is Degoat??
The only stupid question is the one ya don't ask.
HERE'S a link to the post in the Vulcan Verses about what the goats belly is and how to de-goat
1 - 20 of 29 Posts
